Perfect Stain Mix For Dark Chocolate Brown Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 04-13-2009, 01:00 PM   #1
Perfect stain mix for dark chocolate brown floor
We have just installed a brand new rift sawn white oak floor in our home and would like to achieve a deep dark chocolate finish. Can someone share that perfect mix of minwax stains (or other manufacturer) to get this very dark brown result on white oak? I have been told to try 50/50 Jacobean-Ebony, also 50/25/25 Jacobean-Red Mahog-Ebony. Are two coats of stain necessary? Also, should we use an oil based poly? Samples I have seen give the floor an amber tone.
Fully apprec!
finbriar is offline   Reply With Quote
Old 04-14-2009, 06:54 AM   #2
This is a personal design choice, so no one can give you the right mix. And stains differ in how they look depending on the wood. Try some mixtures on a scrap piece of the flooring until you find thind the right color. Be sure to appy the final finish also, since most stains change color with the final finish(poly, etc)
Old 04-14-2009, 07:19 AM   #3
Go for 50/50 Mahogany Ebony.
Dana
Dana11 is offline   Reply With Quote
prep existing concrete floor for acid stain sethco Flooring 3 11-10-2010 08:56 AM
Problem with stain on Laminate Floor Lilypebbles Flooring 4 11-04-2009 05:06 PM
The perfect brown - is there one? mischka222 Painting 12 01-24-2007 09:13 AM
