Peel & Stick Vinyl Tiles - Flooring - DIY Chatroom Home Improvement Forum
Old 10-13-2011, 03:54 PM   #1
I want to lay down P & S tiles over a vinyl sheeting floor. It is only one layer of existing, do I need to remove or how do I prep the floor, can I grout over the P&S when I am done with this floor underneath?? Also the floor is coved about 4 inches high, will peel & stick go up that high with out bending?
Thanks!!
rachel23 is offline   Reply With Quote
Old 10-13-2011, 05:15 PM   #2
Mark Potter's Avatar
Rewards Points: 150
Thanks!!
Is the vinyl glued to the floor or is it no glue vinyl?
Can you please explain more on the 4" hight? P&S will crack if it bends or not flat
I have seen P&S layers on top of each other.
Lots of people do this its common although over a wooden floor like 1/4" sanded plywood to install the self stick tiles to will last much longer.
Make shore u acclimate the P&S before install meaning leave them in the room for about 48hrs or they won't stick make shore the room is worm for that time.
And go by the pattern if there styled.
Mark Potter is offline   Reply With Quote
Old 10-13-2011, 05:52 PM   #3
Ok so probably not going to be able to cove it (is that the right term??).. when the vinyl sheeting goes up the wall to act like a border. Mine is 4 inches high.. How would I lay down the plywood, can it go over the existing floor or do I need to remove it? My exsisyting floor I believed is glued down..it's probably 30-40 years old so I am not sure
Old 10-13-2011, 06:09 PM   #4
Rewards Points: 150
Oh so you don't have wood trim on the bottom of the room it's the vinyl? What room are you doing this in? Can you provide picture? Of the room and what you have in there now?
Old 10-13-2011, 06:10 PM   #5
DIY staff
Rewards Points: 7,174
Is the old vinyl smooth or embossed?(indented pattern)
Old 10-13-2011, 06:26 PM   #6
It is embossed, its for our Kitchen. And yes its the vinyl that goes up the wall..I'll get a picture up ASAP
Old 10-13-2011, 06:36 PM   #7
DIY staff
Peal and stick likes a very flat surface---if you wish to stick it to old embossed vinyl the imbossing need to be filled in.
There is a product called 'embossing leveler' sold in the flooring section of the stores.
It is very expensive---but will allow you to set the peal and stick on top without any hollow spots.
Cut out the rolled wall section and add regular wood molding.
Rusty Baker had a lot of experience in this area ( I am a ceramic tile guy) --If he adds a suggestion--listen to him.----Mike----
Old 10-13-2011, 08:28 PM   #8
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 142
Are these the newer groutable tile or the old type peel & stick?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 10-13-2011, 09:58 PM   #9
Rewards Points: 150
How can any P&S be groutable?.. Lol
Old 10-13-2011, 10:35 PM   #10
Rewards Points: 142
Don't laugh, there are some.
http://mariesteris.hubpages.com/hub/...le-Vinyl-Tiles
Old 10-14-2011, 05:21 AM   #11
Rewards Points: 150
Oh ok lol I was starting to question reality!.. Or maybe still am lol
Old 10-16-2011, 06:17 PM   #12
I wont do the grout able tiles. Is it just easier/cheaper to tear out old stuff and new subfloor than doing the leveler?
Old 10-16-2011, 06:28 PM   #13
Rewards Points: 150
I think I'm going to do that on my next small bathroom job Im very curious?.. About it now very curious lol
Old 10-16-2011, 07:14 PM   #14
DIY staff
I don't like to stack new flooring on top of old--so most times I do remove the old vinyl and the 1/4" underlayment-
Then install new plywood underlayment (not luan ply) --roll on a coat of 'bond enhancer' for good luck and stick the tiles.
Using embossing leveler is faster and cheaper --but the job has a higher failure rate than a new inderlaymet.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Do I fill the cracks when I am putting peel and stick tiles? bherdman Flooring 5 04-05-2010 04:01 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 06:08 PM
Sealing Vinyl floor Tiles? Platinum Flooring 5 11-01-2009 06:32 PM
Peel and stick matching melkisadek Flooring 6 01-16-2008 07:52 AM
