Peel & Stick Tiles Onto Plywood Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 01-24-2009, 12:03 PM   #1
Peel & Stick Tiles onto Plywood Subfloor
We are finishing our bathroom in our basement. We were told not to stick the tiles directly onto this type of floor as over time they will pull up. Can we maybe put down a vinyl adhesive first then put the tiles on? Any suggestions will be appreciated.
kimmyb is offline   Reply With Quote
Old 01-25-2009, 08:43 AM   #2
Rewards Points: 150
What type are you referring to? Concrete?
I moisture present?
mike costello is offline   Reply With Quote
Old 01-25-2009, 09:56 AM   #3
There is no moisture, completely dry. Sorry it is not plywood, but chipboard underlayment. We were thinking of laying down vinyl adhesive first so as to ensure adhesion.
Old 01-25-2009, 10:10 AM   #4
Rewards Points: 150
ok, its either particle board or Advantech.
You will need to put a subfloor down over it before the tile. Nothing sticks to that stuff.
A 1/4 inch layer of either Multiply or Halex will do the trick.
You would need to be more specific about what type of vinyl adhesive you are thinking of. Clear spread vinyl tile adhesive is ok to use and will help with the longevity but as a whole peel and stick ties tend to shrink over time because they are typically not that stable.
After putting the subfloor some primer applied will help with the adhesion
Old 01-25-2009, 02:09 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 212
Mike,
Maybe you missed it when kimmy said the floor is a basement bathroom?
Kiimyb,
You can not install an OSB or plywood to a concrete slab and expect it to work well long term. Your P&S tiles should be stuck to the concrete. Depending on the condition of the floor it may work OK. You can apply clear thin spread adhesive for better results. Make sure the glue "sets" before you install tiles. This can take 1-3 hours, but tiles can be installed even the next day or so.
Jaz
Old 01-25-2009, 04:07 PM   #6
Rewards Points: 150
Title of the thread says plywood and she told me it was chip board.
Its more than likely a sleeper floor.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Peel and stick matching melkisadek Flooring 6 01-16-2008 08:52 AM
Will vinyl tiles stick to this? rebekkah Flooring 1 01-12-2008 02:04 AM
How do you Lay Large Tiles over Plywood Subfloor? 1655graff Flooring 20 10-01-2007 06:28 PM
subfloor for laminate and tiles mf915 Flooring 10 05-18-2006 05:01 PM
