Peel And Stick Tiles - Flooring - DIY Chatroom Home Improvement Forum
Old 05-04-2013, 08:58 PM   #1
Electrician
Rewards Points: 794
Peel and Stick Tiles
I am looking at getting some peel and stick tiles to replace my floor in my camper and have a couple of questions.
The store I have looked in have two types of tiles, the cheap ones which feel cheap, there flimsy when you pick them up. The second is the more expensive tile but feel a lot stronger then the cheap ones. Is it worth the money to buy the more expensive ones.
I see on the package that you can grout the tiles, is this a neccassary step or will butting them up to each other be good enough.
darren is offline   Reply With Quote
Old 05-05-2013, 04:33 PM   #2
Too Short? Cut it Again!
The thinner tiles may fracture on you especially if you floor is not perfectly flat so get the thicker ones. Over time the are more prone to loose flex and dry out too.
If you are putting them in a wet area, grouting/sealing them is not a bad idea.
Make sure you follow prep instructions.
Old 05-05-2013, 04:44 PM   #3
DIY staff
Rewards Points: 7,174
Henrys Bond Enhanser is a good first step to insure a good bond---
Old 05-05-2013, 06:25 PM   #4
747
registered
747's Avatar
Rewards Points: 534
Yep this is what i used. Also on the back of the tiles there are arrows make sure you lay according to them. Or at least there was on mine. They were Armstrong.
747 is offline   Reply With Quote
The Following User Says Thank You to 747 For This Useful Post:
oh'mike (05-05-2013)
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Peel and Stick Vinyl tiles nunie305 Flooring 3 03-06-2012 02:04 AM
Peel and Stick Vinyl Tiles tscan Flooring 4 11-14-2011 07:10 PM
Peel & Stick Vinyl Tiles rachel23 Flooring 13 10-16-2011 07:14 PM
Do I fill the cracks when I am putting peel and stick tiles? bherdman Flooring 5 04-05-2010 04:01 PM
