-   -   Peel and Stick Tiles (http://www.diychatroom.com/f5/peel-stick-tiles-178771/)
darren 05-04-2013 09:58 PM
I am looking at getting some peel and stick tiles to replace my floor in my camper and have a couple of questions.
The store I have looked in have two types of tiles, the cheap ones which feel cheap, there flimsy when you pick them up. The second is the more expensive tile but feel a lot stronger then the cheap ones. Is it worth the money to buy the more expensive ones.
I see on the package that you can grout the tiles, is this a neccassary step or will butting them up to each other be good enough.
user1007 05-05-2013 05:33 PM
The thinner tiles may fracture on you especially if you floor is not perfectly flat so get the thicker ones. Over time the are more prone to loose flex and dry out too.
If you are putting them in a wet area, grouting/sealing them is not a bad idea.
Make sure you follow prep instructions.
oh'mike 05-05-2013 05:44 PM
Henrys Bond Enhanser is a good first step to insure a good bond---
747 05-05-2013 07:25 PM
Yep this is what i used. Also on the back of the tiles there are arrows make sure you lay according to them. Or at least there was on mine. They were Armstrong.
