Old 11-03-2009, 05:14 PM   #1
Default Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor
I recently purchased a home that my wife is not happy with and we're going to sell : (
The bathrooms in the home are all original (built in 1970). I recently redid the powder room with new vanity, mirror, lighting, toilet, sink, etc. Everything except for the original white ceramic tile floor, which in the powder room, still looks good.
However, the master bathroom (which is very small) has pink ceramic tile, and the center-hall bathroom has blue tile.
Our realtor is advising that some of his past clients have put Armstrong peel and stick tiles (they're about $30 per case he said) over top of the existing ceramic tile floors. The existing floors are the smaller square tiles, not the 4"x4". They do have grooves, so I was thinking I'd at least need to use leveler of some sort to fill the slight grooves.
I am well aware that, contrary to what the realtor is advising, that these original floors should be ripped out, but I'm selling the house as quickly as possible and I have never removed ceramic tile floors like this.
So my questions are:
1. How hard is it to remove these floors? The bathrooms are relatively small. One is tiny, the other is medium-sized.
2. What would be underneath them? This house was built in 1970.
3. Can I just do like the realtor said and clean the floor real good and slap the peel and sticks over top of the existing tile floors? Will they stick? Is leveler needed?
mark2741 is offline   Reply With Quote
Old 11-03-2009, 06:05 PM   #2
Pretty much your realtor is an idiot. Removing ceramic floors is difficult, and then the flooring must be replaced. Self stick tiles are an atrocious product, and are not meant to stick to a glassy surface. Your best bet is to do nothing, or to drop the price. But partaking in an abortion of a flooring job is not the way to make a quick sale
Anti-wingnut is online now   Reply With Quote
Old 11-03-2009, 08:08 PM   #3
37 year installer
rusty baker's Avatar
According to most of the realtors that I deal with, you are better off to offer a small reduction in price than to do some horrible coverup.
If'n you can't fix it with duct tape, it can't be fixed!
More On This Topic
Hi my name is Jeremiah Johnson; I’m the owner and operator of S&J Cleanaway. I’ll be demonstrating how to remove adhesives from a floor, this can also double for non-stick pads inside of a shower or bathtub or just anything that would... Read More »
You love your kitchen floor because of the real tiles laid on it. You like the color, but you like the color even better when the tiles are wet, and they look more vibrant. But read below for some other ways to add some shine to your ceramic or slate... Read More »
How to Remove a Toilet
How to Remove a Toilet by Expert Village
Today we’re replacing a dead toilet, one that leaks real bad. What we’re going to do is after you clean the area and get everything all prepped, you’re going to disconnect the water supply. We already have the water turned off. You just... Read More »
I’m Lee. I have a degree in architecture and about ten years in the construction field and today we’re doing a fairly ornate countertop in my own house. Both of the countertops are using the basic same colors, but it’s a different tile... Read More »
Hi my name is Frank Clarke with Oliver and Associates Realty in London Ontario on behalf of expertvillage.com. I want to discuss with you another bathroom. This is the on-suite bathroom the on-suite bathroom just happens to be a four piece bathroom it... Read More »
Seal Peal and Stick Tiles? Echo1 Flooring 15 08-12-2008 08:59 PM
Prep for peel n stick over peel n stick furball Flooring 0 03-31-2008 10:29 PM
Peel and stick matching melkisadek Flooring 6 01-16-2008 09:52 AM
Advice on installing bathroom floor fourstringdrums Flooring 8 02-26-2007 03:56 PM
Installing 'peal and stick' vinyl squares on top of existing .... alexz Flooring 8 02-17-2007 06:20 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
