Peel And Stick Tile. - Flooring - DIY Chatroom Home Improvement Forum
Old 07-20-2010, 05:16 PM   #1
Peel and stick tile.
Is there any reason I can't use mastic or thinset with peel and stick tile? I had to replace a particle board floor that had been ruined by a water leak with 3/4 in. plywood. This is in a bathroom and I already have the peel and stick on hand. Just think it would be better to glue it since this area is prone to getting wet....Thanks.
remarc is offline   Reply With Quote
Old 07-20-2010, 05:58 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 38
If you want to glue it, don't use products made for ceramic. Use vinyl floor tile adhesive.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 07-20-2010, 06:24 PM   #3
Thanks for the reply. I have some vinyl tile glue on hand too.
Peel and stick vinyl flooring over absteos tile? Codchamp Flooring 3 07-17-2010 07:17 PM
Do I fill the cracks when I am putting peel and stick tiles? bherdman Flooring 5 04-05-2010 05:01 PM
Re-Roofing: Okay to Re-Use Peel n Stick? GrillMouster Roofing/Siding 8 12-06-2009 02:55 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 07:08 PM
Peel and stick matching melkisadek Flooring 6 01-16-2008 08:52 AM
