Pavers Over A Concrete Sidewalk - Flooring - DIY Chatroom Home Improvement Forum
Old 08-23-2008, 09:31 AM   #1
Pavers over a concrete sidewalk
Hi
I'm planning to lay thin brick pavers over the concrete sidewalk leading up to the front porch. The problem I have is that the sidewalk is not even and level in certain areas. Specifically, certain section of the concrete side walk are sloping to the left. It's at least an inch out of level. I know I have to thinset the pavers to the outside edge of the sidewalk to be able to lock in the inner pavers. My question is this: How in the world do I level out that sidewalk? I can't really use sand, because I can't obviously thinset the outside pavers to a sand surface. If I thinset the outside pavers to the concrete, then sand the middle to level it out, the pavers in the middle will raise higher than the pavers on the outside edge of the side walk. That would look very cheesy. Any ideas?
Thanks.
Beckerad is offline   Reply With Quote
Old 08-23-2008, 01:16 PM   #2
ccarlisle's Avatar
Yeah, SLC self-levelling cement. Build a frame around the areas that need levelling, make up a batch and pour till it evens up with the rest. Use an adhesive underneath the SLC first if you want.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 08-23-2008, 02:08 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Not all SLC's are suitable for exterior use.
To form it and top it with about two inches of cement would be less expensive.
Old 07-20-2010, 08:59 PM   #4
There is of course the option to install the concrete pavers over an aggregate base...this would require you to remove the sidewalk, however.
Will
WillGrander is offline   Reply With Quote
How to precision cut concrete pavers? tripower Landscaping & Lawn Care 13 06-29-2008 04:46 AM
Sealing Concrete Pavers Kyle Landscaping & Lawn Care 2 06-26-2008 08:35 PM
Concrete Pavers and Stain terryhflyer Flooring 2 06-04-2008 04:59 PM
Gluing Pavers to Concrete cibula11 Building & Construction 1 07-16-2007 06:16 AM
Sidewalk Meets Concrete Truck Question craigNeasttx Building & Construction 5 03-24-2005 11:40 PM
