Patching Existing Hole In Floor From Former Toilet Drain - Flooring - DIY Chatroom Home Improvement Forum
Old 05-06-2010, 08:37 AM   #1
patching existing hole in floor from former toilet drain
I have converted a former bathroom into office space. The floor is 3/4 ply with basement below. What is the best method to close up the hold that is left behind from the toilet drain?
ftlng is offline   Reply With Quote
Old 05-06-2010, 08:42 AM   #2
whats the flooring finish
The older I get the better I was
Old 05-06-2010, 08:50 AM   #3
floor finish
The floor is currently just the wood subfloor. I am going to be doing carpet tile over it.
Old 05-06-2010, 09:24 AM   #4
cut a square 3/4 blank plywood square slightly larger than existing hole, lay this over hole and draw outline on floor. cut out new hole. make another square3/4 several inches larger than new hole, glue and screw to underside of hole. Take first square and glue and screw into hole. you can skim gaps in edges with adhesive or skim compound. for added strength if needed you can add blocking from basement under 3/4 support piece by nailing joist to joist
Toilet leaking from seat mounting hole jrpoole59 Plumbing 11 05-05-2010 10:25 AM
Toilet bowl won't drain. Sikorsky Plumbing 5 12-31-2009 06:05 AM
Toilet Drain Distance from Wall? jonathan03 Plumbing 16 12-24-2009 12:23 AM
Can I connect toilet drain to this drain pipe james739 Plumbing 11 04-24-2009 07:06 AM
New shower with existing drain jamesdcarroll Remodeling 1 02-08-2008 02:13 PM
