Old 12-19-2012, 03:56 PM   #1
Patching after sand topping?
I used sand topping to fill around new drain pipes in basement slab. I didn't bring it up high enough mainly because I thought I'd use Henry's floor patch for the fine finishing.
The question is can I use Henry's patching right over the sand topping?;should I wait for sand topping to cure?; would a "primer" be needed?;
Squeakyhinge is offline   Reply With Quote
Old 12-19-2012, 07:58 PM   #2
Wait for the topping to cure. Henry's will bond to it. I don't think you'll need to prime, but checks Henrys' website to be sure.
Seattle2k is offline   Reply With Quote
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 7 05-06-2012 11:43 PM
Patching asphalt driveway, so cal tns1 General Discussion 2 02-12-2012 07:15 AM
Eco-friendly cement patching compound asciiman Flooring 2 02-19-2010 07:17 PM
Smoothing Joints Between Sheetrock and Plaster Without Sanding OldManMike Building & Construction 6 06-30-2009 08:42 PM
