Old 02-03-2006, 10:03 AM   #1
Question
Particle board underlayment help
Help
We are doing a whole house remodel, and the whole house has 1" particle board on top of 1/4" plywood...... The only thing we can put on top of this is carpet and vinyl we want wood and or tile.... Can we put 1/4" plywood over the particle board pulling up the particle board is not what we want to do
diynut is offline   Reply With Quote
Old 02-03-2006, 12:56 PM   #2
Floorwizard's Avatar
Forget tile.
But you can do a floating wood.
Tile is possible, but requires more work.
Floorwizard is offline   Reply With Quote
Old 02-06-2006, 12:58 PM   #3
Does anybody have any ideas about Aundra?? I think that how it spelled?
Old 02-06-2006, 03:06 PM   #4
The particle board and 1/4 layer has to come up if you want tile, nothing can go over it for tile, what's under that subfloor.?)
R&D Tile is offline   Reply With Quote
Old 03-06-2006, 10:19 PM   #5
We have 1" particle board and 3/4" plywood????
Can we put 1/2" plywood over the particle board... using 3" screws
Old 03-07-2006, 06:22 AM   #6
You sure you don't have OSB?, if particle board, NO, if you plan on tiling, it can't be anywhere in the mix, EVER.:D
Installing backerboard - replace particle board? salvop Flooring 10 04-29-2011 11:32 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 08:44 PM
1/4" usb board underlayment in bathrooms thehulk1978 Flooring 3 12-05-2006 05:16 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
particle board / hardibacker fish3211 Flooring 4 08-10-2005 09:32 PM
