Old 08-04-2005, 01:30 PM   #1
particle board / hardibacker
I have seen numerous posts concerning the required removal of particle board underlayment prior to using hardibacker. In the process of removing old carpeting, I have sections of the house which has 3/4 inch plywood while other sections have a combination of 1/2-inch plywood covered by 1/4-inch particle board. Floor has 2X10 floor joists on 12 inch centers, double joists every 3 feet. Is it possible to overlay the 1/4-inch particle board with a 1/4-inch exterior grade plywood and then install the thin-set with the hardibacker? Rather not remove 1/4-inch particle board if possible since it may be glued down to the 1/2-inch plywood.
In advance, thanks for any information that you have.
fish3211 is offline   Reply With Quote
Old 08-06-2005, 09:23 AM   #2
aka:awesomedell
Send a message via MSN to housedocs
Particle board isn't an acceptable underlayment for tile period, per TCA specs. In fact IMHO it isn't acceptable for anything other than making speaker boxes maybe. If it gets wet at all it will swell and cause you problems, and it's going to get wet when you put thinset on it to set the hardibacker.
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
Old 08-06-2005, 11:50 PM   #3
Contractor
In response to Housedocs, DITTO.
IMHO, particleboard does not belong inside of a house. I think of it as a long term release fertilizer, outside.
Recycle when you can.
Teetorbilt is offline   Reply With Quote
Old 08-07-2005, 01:14 AM   #4
Just for reference Hardi makes a backer that is 1/2" thick.
JustaFramer is offline   Reply With Quote
Old 08-10-2005, 09:32 PM   #5
I've never seen particleboard that thin before, Then again I've never looked for it, either.
If you're sure its 1/4", maybe find an inconspicuous area (one that will wind up under a couch or bed or something in case it doesn't work), drop your circular sawblade to 1/4" and cut a square. See if it comes up. That should at least tell you if it will come up.
Neil_K is offline   Reply With Quote
Installing backerboard - replace particle board? salvop Flooring 10 04-29-2011 11:32 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 10:33 PM
Particle board underlayment help diynut Flooring 5 03-07-2006 06:22 AM
