-   -   particle board / hardibacker (http://www.diychatroom.com/f5/particle-board-hardibacker-870/)
fish3211 08-04-2005 12:30 PM
I have seen numerous posts concerning the required removal of particle board underlayment prior to using hardibacker. In the process of removing old carpeting, I have sections of the house which has 3/4 inch plywood while other sections have a combination of 1/2-inch plywood covered by 1/4-inch particle board. Floor has 2X10 floor joists on 12 inch centers, double joists every 3 feet. Is it possible to overlay the 1/4-inch particle board with a 1/4-inch exterior grade plywood and then install the thin-set with the hardibacker? Rather not remove 1/4-inch particle board if possible since it may be glued down to the 1/2-inch plywood.
In advance, thanks for any information that you have.
housedocs 08-06-2005 08:23 AM
Particle board isn't an acceptable underlayment for tile period, per TCA specs. In fact IMHO it isn't acceptable for anything other than making speaker boxes maybe. If it gets wet at all it will swell and cause you problems, and it's going to get wet when you put thinset on it to set the hardibacker.
Teetorbilt 08-06-2005 10:50 PM
In response to Housedocs, DITTO.
IMHO, particleboard does not belong inside of a house. I think of it as a long term release fertilizer, outside.
Recycle when you can.
JustaFramer 08-07-2005 12:14 AM
Just for reference Hardi makes a backer that is 1/2" thick.
Neil_K 08-10-2005 08:32 PM
I've never seen particleboard that thin before, Then again I've never looked for it, either.
If you're sure its 1/4", maybe find an inconspicuous area (one that will wind up under a couch or bed or something in case it doesn't work), drop your circular sawblade to 1/4" and cut a square. See if it comes up. That should at least tell you if it will come up.
