Particle Board Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-14-2011, 11:54 AM   #1
Hey Guys,my wife wants to tile our bathroom floor.Pulled up vinyl flooring and there is particle board flooring over joists,that's it.Don't want to replace floor.Can we paint waterproof membrane over it,then thinset and then put down backerboard? If this is ok can you suggest a good membrane product?
saw04 is offline   Reply With Quote
Old 11-14-2011, 12:08 PM   #2
I'm no expert but my house was built in 1977 and there is (and was) particle board throughout. I've renovated about 50% of my house and ALWAYS remove the particle board. It is a terrible material that readily absorbs water and not to mention, has formaldehyde in it (use mask if removing). I would recommend taking it out and replacing with plywood.
kadams2345 is offline   Reply With Quote
The Following User Says Thank You to kadams2345 For This Useful Post:
saw04 (11-14-2011)
Old 11-14-2011, 12:34 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Have you never read the instructions on any of those products? What do they say about use with particleboard?
The Following User Says Thank You to Bud Cline For This Useful Post:
saw04 (11-14-2011)
Old 11-14-2011, 01:04 PM   #4
I was under the impression we could put the thinset down at least to cover any low spots and then add the backerboard.
Old 11-14-2011, 01:17 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Read the instructions on the thinset package. The same information is on every bag of thinset I have ever seen.
saw04 (11-14-2011)
Old 11-14-2011, 01:43 PM   #6
Ok,I'm following you now.Thinset not for particle board.Has to be pulled up and replaced with plywood.Thanks!
The Following User Says Thank You to saw04 For This Useful Post:
oh'mike (11-14-2011)
Old 11-14-2011, 02:55 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Particleboard will not survive the moisture of a thinset application or a liquid waterproofing application. Particalboard is not to be used anywhere in a tile installation.
Old 11-14-2011, 05:17 PM   #8
DIY staff
Rewards Points: 7,174
The 1970s brought a lot of new build products and practices to the market--
Roof trusses---floor trusses--drywall screws and glue---foam board--and particle board among others--
Not all of them worked well---particle board was one of the failures-----
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
How to remove particle board mortared to plywood? k8park Flooring 1 01-02-2011 07:47 AM
Particle board and electrical Outlet HELP!!! NikkiGagnon Electrical 8 01-18-2010 05:52 PM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
particle board / hardibacker fish3211 Flooring 4 08-10-2005 09:32 PM
