Paper Bag Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 07-12-2012, 09:58 PM   #1
Paper bag flooring
Hi, Just wondering if anyone has used the paper bag method of flooring? I'm thinking of replacing our old tiles in the basement laundry room with this method. Any comments or experience with this method? Thanks
tgifwilson is offline   Reply With Quote
Old 07-13-2012, 04:59 PM   #2
hwymorris's Avatar
I've never heard of it? Please explain. I've heard of walls but not floors doing with doing that process.
hwymorris is offline   Reply With Quote
Old 07-13-2012, 07:09 PM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
Must mean floating tile?.....
JetSwet is offline   Reply With Quote
Old 07-13-2012, 08:12 PM   #4
Rewards Points: 13,764
Nope, I'd bet there taliking about one of the sillyest ideas I'd ever heard of.
Cover the floor with paper bags and coat with coats of poly to make it look like leather.
It was all the rage on some of the DIY shows years ago, along will applying toilet paper on the wall with glue and painting over it. (no joke)
Horrible horrible idea.
There has to to be at least 10 other ideas for flooring that will hold up better and last longer.
rusty baker (07-13-2012)
Old 07-13-2012, 08:33 PM   #5
Pro
JetSwet's Avatar
Rewards Points: 502
Oooohhh......nooooo......
Old 07-13-2012, 08:45 PM   #6
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I did something like that on a trashed kitchen counter several years ago. The formica was toast so I figured if it didn't work I wouldn't be out much.
It lasted a couple of years until we sold the house.
No way would I attempt it on a floor.
Old 07-14-2012, 07:10 AM   #7
the Musigician
DangerMouse's Avatar
....and they are....... what?
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
angelbroown (07-14-2012)
Old 07-14-2012, 04:36 PM   #8
Stuck in the 70's
The process is basically white glue and paper with a layer of polyurethane on top. I think it would be a delicate floor at best.
I wonder how many people who endorsed it five years ago are still happy with it.
In a basement laundry room you have potential water and moisture issues. Not my first choice to try it in.
Edited to add: At least it would be cheap and easy to patch or repair.
Old 07-15-2012, 06:30 PM   #9
Rewards Points: 264
I agree with the others, this does not sound like too good of an idea. Maybe consider Cork for a some what similar look that is fairly affordable. Other options for a concrete basement floor might be to epoxy it, acid stain, or tile.
Awoodfloorguy is offline   Reply With Quote
Old 07-16-2012, 01:10 AM   #10
Rewards Points: 2,212
Know a guy did this in a trailer and it worked well he said.
Not sure how much I would trust it.
mae-ling is offline   Reply With Quote
why does starter strip have glue on it if it goes on tar paper? KarlJay Roofing/Siding 4 11-24-2010 02:05 PM
Flooring for hot tub room with tongue and groove base flooring. tkmiller Flooring 0 10-24-2010 12:21 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 08:53 PM
Felt Paper and the Sun. Valley problems hartkem Roofing/Siding 1 07-22-2009 03:57 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 07:06 PM
