Painting Vinyl Asbestos Tile? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-03-2016, 03:48 PM   #1
Rewards Points: 20
Good evening, I've been in this section a couple times so pardon me. My plan was to cover the vinyl asbestos tile with another type of flooring but due to finances I am restricted from doing that. The cheapest solution I have thought of is to paint over the VAT. Just either stencil or design. Would it be acceptable to do this? It is a temp solution.
Oil based primer, then oil/latex paint, then seal? I don't see any issue other than it being an undesirable solution.
Thank you
jessicurr is offline   Reply With Quote
Old 02-03-2016, 03:58 PM   #2
Rewards Points: 9,792
Why do you think you have to do anything until you have the money to cover it?
Unless your cutting it and causing air born dust it's not doing any harm.
Old 02-03-2016, 04:08 PM   #3
Rewards Points: 20
I'm aware it's no real harm, it's just hideous. It looks like an old hospital or cafeteria.
Old 02-03-2016, 06:11 PM   #4
Rewards Points: 2,622
If you think it will look better that what's there now, go ahead and do it, your the one that has to live with it.
Canarywood1 is offline   Reply With Quote
Old 02-03-2016, 07:32 PM   #5
Rewards Points: 924
Make sure you use a paint specifically designed to handle wear and tear from foot traffic. Vinyl is smooth, so it's not exactly a great surface for paint to adhere to, and some manufacturers recommend you sand the surface for better adhesion, but that's exactly what you want to avoid so hopefully a primer will do the trick. I agree with an oil based primer and paint. Do you have an inconspicuous spot you can test?
spaceman spif is online now   Reply With Quote
Tags
asbestos , flooring , primer , vat , vinyl
Covering 1960's 9x9 vinyl tile with self leveling cement? Suspect asbestos vestaviascott Concrete, Stone & Masonry 17 11-02-2014 06:07 AM
Vinyl Tile over old vinyl? joe14 Flooring 10 08-02-2014 12:43 PM
Large tile over sheet vinyl Mr.Otis Flooring 16 03-11-2014 10:33 AM
want to remove recent vinyl flooring over asbestos subfloor fabster Flooring 5 05-04-2011 01:59 PM
Should I use tile or vinyl Quadfam4 Tiling, ceramics, marble 3 04-30-2009 10:58 AM
