Painting Particle Board Sub-floor - Flooring - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 05:53 PM   #1
Painting particle board sub-floor
Can I paint sub floor that is not plywood...it is fine particle board using the same method as plywood subfloor
jacksok is offline   Reply With Quote
Old 07-11-2011, 06:04 PM   #2
m1951mm's Avatar
It would be helpful to know the reason you are painting the subfloor. Anytime you paint raw wood, IMHO, I use an oil based product for the first coat. Any water based product will raise the grain of the wood be it plywood, mdf, chipboard or the back yard tree. Understanding your goal with the floor will help give you a better answer.
m1951mm is offline   Reply With Quote
Old 07-11-2011, 10:23 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 232
I agree, we need to know what you're doing. Particle board is not a suitable subfloor for just about any kind of flooring. It was pushed back in the '80's because it was cheap, but has proven to be a very bad choice for subfloors.
Jaz
JazMan is online now   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
hardwood on top of particle board troutman Flooring 8 01-26-2011 04:05 PM
Painting DensShield tile backer board warriorfox Painting 2 05-15-2008 05:08 PM
Can particle board be used as a subfloor. Please help blaclightn1 Flooring 11 02-12-2008 04:26 PM
particle board / hardibacker fish3211 Flooring 4 08-10-2005 09:32 PM
