Painting Grout - Flooring - DIY Chatroom Home Improvement Forum
Old 01-01-2011, 10:39 PM   #1
Painting grout
I hate my kitchen tile and grout. I'm not able to replace the tile at this time but am considering either painting the grout or removing it and regrouting it with a more desirable color. Has anyone ever painted their grout? How hard is it to remove grout from a large area? Thanks!
Dotsmom is offline   Reply With Quote
Old 01-02-2011, 12:56 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 290
Do not paint. Use grout stain, it's made just for your problem.
Jaz
Old 01-02-2011, 12:56 PM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
You don't want to paint it, but try googling "grout stain".
As far as removing and replacing the grout, it's not difficult, just time consuming detail work. There are several tools available. You can dig it out manually with tile saw (available at the big box stores). Dremel also makes an attachment for their tools that will speed up the process, but if you use any power tools extra care must be taken not to scratch or damage the tile.
Old 01-02-2011, 01:03 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 290
Talking about brilliant minds. I beat you by a few seconds.
I don't agree about removing the grout though. It's not an easy job as you say. A grout saw will kill your hands. There is absolutely NO reason to remove the grout if it's just the wrong color or dirty.
The best tool to remove grout however is an oscillating type tool such as Fein, Dremel or Craftsman. These cost from $80-500 and come with various attachments.
Jaz
Old 01-02-2011, 01:29 PM   #5
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Yep I find the easiest tool to use for grout removal is a Dremel with the angle head guide on it just for this purpose. The bits eat the grout up in no time and it's easier to use than other option. You will go through bits very quickly though. I agree that staining would be better. Aquamix is probably the most widely available grout dye.
poppameth is offline   Reply With Quote
Old 01-02-2011, 01:36 PM   #6
grout stain
I've actually done this project.
Laundry room grout was gross. Leave the old grout alone.
Grout stain works great. Just like painting it on..but it is made for grout and it stains it the new, cleaner, better color. Box Stores have it!! Not cheap, but a cheap way to freshen your area. Good luck.
mrs. c is offline   Reply With Quote
Old 01-02-2011, 08:04 PM   #7
Thank you!
Thanks everyone for your help. I have about 250 sq ft of tile and most likely won't remove the grout. I have the standard builders tile with a very light gray grout. It needs to be darker so it won't show dirt so easily (I have 7 labs).
I'll probably go the stain route.
Thanks again
Old 01-02-2011, 08:11 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 290
7 labs.......oh boy.
You will need to super-clean the grout using a tile & grout cleaner. It'll contain acid, read carefully, not hard to use but it'll take you several hours to do.
You'll love the grout stain for ease of maintenance. It contains an epoxy base so it'll be permanently sealed and easier to clean.
Wonder what type of flooring is in the rest of the house?
Jaz
Can bad grout job be salvaged? wlsmith Tiling, ceramics, marble 22 11-14-2010 07:31 AM
Painting Skirting Boards and paint dripped into the tile grout naomit111 Painting 2 11-10-2010 10:04 AM
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 08:07 PM
Removing grout from top of ceramic tiles markdrum1 Tiling, ceramics, marble 3 09-28-2010 10:38 AM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 11:59 PM
