Old 02-13-2012, 10:51 AM   #1
Lightbulb
Painting a basemnent floor
I recently purchased a house that had carpet over vinyl tile in the basement. I have ripped up the carpent and now im starting the vinyl tile, I was thinking for the cheapest solution would be to paint the concrete floor. How would I go about painting the floor? What type of paint should I use? Any sealers or epoxys?
jdunaj is offline   Reply With Quote
Old 02-13-2012, 11:02 AM   #2
Not a great idea, the reason being that floor would have to be completly clean with 0 old glue or mastic for the paint to have something to grab onto.
Basements floors are hard on paint, the rising moisture tends to push the paint off of the floors or the bond is so weak it rubs off real easy.
Once you paint it your limited on what type flooring can go down, any glued down flooring will not bond to the paint.
jdunaj (02-13-2012)
Old 02-13-2012, 11:07 AM   #3
What would you recomend? I am on a small budget. The area of the floor I want to do is about 750sq ft
Old 02-13-2012, 11:08 AM   #4
What would you recomend? I am on a small budget. The area of the floor I want to do is about 750sq ft .
Old 02-13-2012, 11:10 AM   #5
A quality sheet linolium would have gone down right over that old tile if it was firmly attached.
Old 02-13-2012, 11:23 AM   #6
no the tile was not secured down good. I can peel it off with my fingers real easy. if I pull up all the tile would i have to sand down the floor to put linolium or can it go over the old glue?
Old 02-13-2012, 06:49 PM   #7
How old is the house? You may want to make sure that those tiles do not contain asbestos before you start ripping them up. If the house was built pre 1980's I would be suspicious.
Not trying to worry you but I ran into that a couple years ago.
mschrade is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
How to repair a concrete floor we just had repaired! timbo59 Flooring 11 01-04-2012 07:15 PM
Preparing an interior concrete floor for painting Melsdetails Flooring 1 08-23-2011 07:08 PM
painting concrete floor MeanGene Painting 1 07-12-2010 02:34 PM
Hardwood Floor Painting Advice / Tips / Tricks? cherie Flooring 3 09-05-2008 10:52 PM
