Painted Oak Floor Help - Flooring - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 03:10 PM   #1
painted oak floor help
good evening
I have been set the task of cleaning an oak floor that has been painted black, the floor has many scuffs from shoes and scuffs and marks from chairs that have metal studs on them, is it possible to get this floor back to its former glory? any advice tips techniques would be very much appreciated
thank you
jamiemilliken is offline   Reply With Quote
Old 04-22-2012, 05:16 PM   #2
Rewards Points: 150
Equipment rental stores have hardwood refinishing tools, floor sanders, edge sanders etc that will cut the existing coats of paint and polyurethane off to get it down to bare wood again.... But,
There is a learning curve on using this equipment and one has to be very careful, once the wood is cut too deep or sanded in the wrong direction, no way to undo it...
Hardwood floors are tongue and grooved meaning they will only allow so many sandings before the groove is so thin, the floor planks will start cracking at the joints....
One really doesnt know how many sandings the floors may have had so a test should be done or maybe a floor register could be pulled up to see how thick the grooves are ...
A pro hardwood floor sander company is the best bet but not cheap. I dont know your budget or what your expectations are for the floor to look like, just what I know about hardwood that may help...
Good luck
Jeeps is offline   Reply With Quote
floors , oak , painted
Seeking help and advice with hideous painted brick fireplace sparkler22 Painting 12 12-03-2011 06:46 PM
How do you fix nails holes in paintable base and casing "after" they are painted? Darkwave Master Carpentry 11 12-17-2010 08:14 PM
All surfaces painted with a brush different from surfaces painted with a roller. praktikal Painting 16 04-06-2010 08:45 PM
Painted the stairs ... . kimber Painting 8 10-07-2009 11:50 AM
Smoothing out a painted and not painted drywall surface MarksHouse Drywall & Plaster 5 10-21-2008 11:50 AM
