Old 12-16-2011, 07:07 PM   #1
painted concrete floor to be covered with ceramic tile
I have a30 year old painted concrete basement floor , I want to install ceramic tile , how much of the paint do I need to remove to ensure the bond is good with the thin set ? or are the alternatives ? The floor is flat ,dry and no cracks .
Any suggestions ?
aussie chris in Va
reseigh is offline   Reply With Quote
Old 12-16-2011, 11:59 PM   #2
Tileguy
JazMan's Avatar
I would like to see 100% concrete, I'd settle for 85%.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 12-17-2011, 06:06 AM   #3
Super Moderator
Rent a floor buffer with carborundum stones---any chemical stripper will soak into the concrete and may cause bonding failure.
Old 12-17-2011, 12:40 PM   #4
Tileguy
Bud Cline's Avatar
Paint is recognized as a major bond-breaker when it comes to installing ceramic tile on top of it so it is recommended that it be removed totally. This should be done mechanically as chemical removal is also discouraged.
Shot-blast, sand-blast, grind, etc.
Can I tile over painted concrete? MarcelFt Tiling, ceramics, marble 3 03-02-2011 12:00 AM
Installing ceramic tile on garage concrete floor erotavlas Flooring 11 02-28-2010 12:01 AM
covered concrete porch..what kind of floor? captjackny Flooring 4 02-26-2010 11:47 AM
ceramic tile onto concrete floor andy36 Flooring 1 08-09-2009 11:54 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 03:26 PM
