Paint After Floors - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-11-2013, 12:03 PM   #16
Amateuralex's Avatar
Rewards Points: 270
Originally Posted by jeffnc View Post
Where did you get the painted trim? Or was it the vinyl trim?
That sounds pretty nice, assuming it's a close match with the white color of the rest of your trim.
Lowes. It's mdf so it's lightweight. Easy to cut, conforms to floor, not very durable. It was cheap too. I just put it in the back parts of the house. Ill have to see if it lasts.
Amateuralex is offline   Reply With Quote
Old 04-11-2013, 12:47 PM   #17
Rewards Points: 878
Assuming you have painted (not stained) trim, then yes, the caulk is painted over when the trim is painted. If the trim is white (pretty standard), then the caulking doesn't always need to be painted where the trim meets the wall, if they do a good job rolling out the caulk. If they do a bad job, then you'll need to touch up the walls anyway. I would use a white caulk, not clear. Clear caulk needs to be painted over completely, everywhere. White caulk on white trim won't be noticed and is opaque, so it covers all dark lines where there are gaps.
So don't paint the trim before it's installed? Can't I paint it then install it? Thanks
Mstrlucky74 is offline   Reply With Quote
Old 04-11-2013, 12:56 PM   #18
Rewards Points: 4,796
Painting the trim first is much easier. If the caulk color doesn't match the paint color, then you'll have to touch up the trim paint after installing. I'd rather paint the trim off the wall and then touch up, than paint it all after installing.
jeffnc is offline   Reply With Quote
Paint before or after installing floors? JumpinJW Remodeling 25 02-14-2012 02:27 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
get paint off concrete floors Hoepfl Flooring 1 08-12-2010 10:01 PM
Paint on floors sgarhs1 Flooring 2 06-30-2009 07:51 PM
How to get paint off finished hardwood floors? BradG Painting 4 06-14-2008 07:14 PM
