P50 Nailer Splitting Tongues On Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 11:57 AM   #1
P50 nailer splitting tongues on flooring
I hired a Powernailer P50 to do my floors with, and I've been practicing on it with some spare flooring and a piece of ply. I've got it adjusted correctly to the height of my flooring, and the psi is right on the money of what the manufacturer recommends. I'm finding though that I'm getting a bit of splitting - do I have to adjust the psi, or is it just the nature of the solid hardwood and the fact it's only 1/2" thick (with a matching thinner tongue) that's causing the issue?
Any ideas or suggestions?
SBishop is offline   Reply With Quote
Old 02-15-2012, 12:34 PM   #2
woodman58's Avatar
Sounds like it might be a poor grade used for the plywood core. With the Powernailer 50P it should not slit the tounges if it is set right. Make sure the gun is set right against the wood before hitting the head. Good luck.
I LOVE THE SMELL OF SAWDUST IN THE MORNING!
woodman58 is offline   Reply With Quote
flooring nailer JCG Flooring 6 12-07-2011 06:02 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
hardwood tongue is splitting with nailer atomilano Carpentry 10 05-04-2009 08:05 AM
Installing Bamboo Flooring with Brad Nailer? aaks38 Flooring 3 11-04-2008 09:11 AM
Nailer for flooring mpt1123 Tools 2 07-08-2008 12:24 PM
