Overhang Lenght On Treads Over Risers????? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-01-2008, 05:54 PM   #1
Rewards Points: 22
overhang lenght on treads over risers?????
I need some help here as this is something new to me. I am installing new oak treads and painted risers but am unsure about something, is there a "universal" lenght that the tread should overhang the riser?
Thanks in advance for any information you can provide.
Rockey
rockey is offline   Reply With Quote
Old 09-01-2008, 07:28 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 240
The overhang should be from 3/4" - 1 1/4". Tread depth min. 9 1/4".
Jaz
JazMan is online now   Reply With Quote
Old 09-01-2008, 07:46 PM   #3
Registered User
Termite's Avatar
As JazMan said, 3/4" overhang is the minimum IRC code requirement. 1-1/4" is the maximum overhang allowed by code.
FYI, maximum rise is 7-3/4". Minimum run is 10" (measured horizontally from nose to nose) in the International code, and has been since 2000. But some areas are still on old codes, so check and see what's applicable in your area.
Here's a link to a great website. On the right side of the page is a .pdf download of a visual interpretation of the stair codes. It is a very handy thing to have printed off when you're building stairs, handrails, or guards.
http://www.stairways.org/codes_standards.htm
Old 09-01-2008, 08:48 PM   #4
Rewards Points: 22
Thanks folks for the replys, this really helps me out quite a bit. I wasnt sure how much overhang to leave but i do now.
Thanks once again
Rockey
How do I install trim around stair treads? JayBird Carpentry 22 08-07-2010 05:16 PM
installing stair treads. Wild Duk Flooring 4 05-20-2008 10:56 AM
Staining treads, painting risers QueenL Building & Construction 5 04-13-2008 10:23 PM
Pennsylvania Bluestone Treads rjordan392 Building & Construction 4 03-30-2008 11:37 PM
tight overhang clearance on gable abutment - how to cover...? rtoni Roofing/Siding 7 10-12-2007 12:13 AM
