Old 06-03-2008, 09:41 AM   #1
outside tiles
What is the best tile to use outside. i have a closedin/covered porch with a concrete pad. i want to put tile out there. what is recomended.? terra cotta, slate? any ideas? thanks
JAVAMAN is offline   Reply With Quote
Old 06-03-2008, 10:13 AM   #2
Tile Contractor
Bill_Vincent's Avatar
outside tiles
It depends on where you are. If you live in an area where freeze/ thaw issues are a consideration, then hands down, porcelain is your best bet. It had virtually no absorbsion to it, and therefore won't pop due to frost. The good news is that porcelain comes in an unbelieveable variety of shapes, sizes, colors, and TEXTURES.
"Whether you think you can, or you think you can't, You're probably right."
Bill_Vincent is offline   Reply With Quote
Old ceiling tiles - remove? repaint? sertiphyible Remodeling 5 08-24-2008 11:36 AM
Will vinyl tiles stick to this? rebekkah Flooring 1 01-12-2008 02:04 AM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 04:07 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 08:43 PM
Vinyl Tiles over pre-existing layers Thwiipp Flooring 1 09-05-2006 02:10 PM
