Outside Tile Floor Is Leaking Onto Ceiling Below - Flooring - DIY Chatroom Home Improvement Forum
Old 04-13-2008, 08:41 PM   #1
Outside tile Floor is leaking onto ceiling below
I have a serious problem with a flat roof that has been tiled with slate tiles and is located on a 2nd story patio positioned directly above a living area. It has started leaking water through the ceiling below.
The leaks started this past winter when snow accumulation melted. I initially thought it might have been caused by a lack adequate flashing but recently we've had some heavy rains and that caused additional leaks. These leaks may have entered through the grout around the slate tile.
What is the best way to solve this problem and affect a proper repair? Can I put tile down again? The house is stucco or EFAS. The size of this roof patio is about 6' x 9'. There are two sidewalls and a solid front wall about 30'' tall which acts as a railing made out of stucco or EFAS with a 2" slit at the bottom to handle rain water and debri. Unfortunately, the floor is almost completely flat with only the slighest runoff towards these slits.
How do you propose I solve this problem? Any thoughts would be greatly appreciated.
Bob
brutter is offline   Reply With Quote
Old 04-13-2008, 09:01 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
wwwwwwwww
tinner666 is offline   Reply With Quote
Old 04-13-2008, 09:25 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 422
Your problem isn't the slate or cracked or missing grout, it's the lack of or damaged waterproofing under the installation. Neither slate or grout are waterproof, neither is any other type of tile.
Sounds like you are looking at a complete and proper redo in the future.
Jaz
Old 04-15-2008, 05:44 PM   #4
Leak
Jaz
How do you suggest I complete this redo properly? Should I use something like Schulter-Ditra or an EDPM liner to route mositure?
Bob
Old 04-15-2008, 05:48 PM   #5
How should I proceed with a proper redo to fix my problem. Should i use something like Schluter Ditra or an EPDM liner to catch moisture? What do you suggest? What about side-wall sheathing and getting it to stick to EFAS.
Bob
Old 04-16-2008, 09:33 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 422
If it's been there many years and just recently started to leak, I would say you probably have a great deal of hidden damage? I think you have to rip it out and start from scratch. Once you see what you've got you'll know better what to do. There are many methods including does you'll find at Schluter's site.
Jaz
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 12:05 PM
Ceiling Fixture is leaking? fbk2000 Electrical 4 01-22-2008 03:33 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
ceiling leaking shoflytux Roofing/Siding 3 03-01-2007 09:46 PM
