Old 05-02-2007, 10:14 AM   #1
Outside corners to two different baseboard rooms
I have run into some difficulties installing baseboards.
I am installing white 4 1/4" decorative baseboards (no quarter-round) in our newly hard wood floored rooms.
The problems is transitioning into our kitchen where there is 3" stained
baseboards WITH quarter-round.
Any suggestion on what to do? Would corner posts work on different sized and colored baseboards?
Thank you for any tips/suggestions.
cygnusx1 is offline   Reply With Quote
Old 05-02-2007, 12:56 PM   #2
Terminate the moulding 1 1/2" before the corner.
Make a 45% back cut, and glue in a small filler piece.
The diagram would be looking down at the floor:
Jeekinz is offline   Reply With Quote
Old 05-02-2007, 11:56 PM   #3
this is correct. It's called a self-return. Cut an outside 45 degree miter where you want the base to end, then the filler piece is made by cutting the opposite direction 45 degree miter as if you were going around a corner but then you cut it off flush to the wall....I dont know how to explain it any better...maybe someone could word it better for me...good luck.
send_it_all is offline   Reply With Quote
Old 05-03-2007, 07:58 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Picture example of a self-return:
- Build Well -
Old 05-03-2007, 08:06 AM   #5
I am sorry, I do not get it.
Cut the two different baseboards 45 in I get. What do I put on the corner after cutting? Corner trim (see picture)?
One thing I forgot to say is that the white (blue) baseboard is 8/16" while the 3" (red) brown baseboard & quarter-round is much thinner.
The brown represents corner trim.
Old 05-03-2007, 08:34 AM   #6
You could install base shoe there...quarter round maybe?
- Build Well -
Old 03-04-2009, 06:58 PM   #7
I installed 6" & 3/4" mop-boards (baseboards) made of birch in the home I just finished building. I routed a Victorian style design along the top edges, and added quarter-round along the floor edges.
I plan on cutting plinths to the bottom of each door frame (which is also birch and 3" 1/2" wide) where the baseboards meet the door frame. The plinths will also have a similar routed edge.
Question: Would it be appropriate from an esthetics point of view to make the plinths taller than the baseboards, say about 1"1/2" to 2" taller? Or the same size as the baseboard. I want this to look professional, and not like it was done by an amatuer (even tho I'm slightly this side of the amatuer rating ). Nor do I want the plinths to compete with the baseboards.
THNX
Downdraft
downdraft is offline   Reply With Quote
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 04:10 PM
Baseboard corners help jcurts75 Carpentry 3 07-08-2007 07:49 AM
Tile Baseboard leted_82 Flooring 3 07-07-2007 12:57 PM
Need help with finding very wide baseboard Showbiz Carpentry 2 05-28-2007 08:52 AM
Baseboard Question in New Home BusterPercheron Building & Construction 5 11-20-2006 07:16 AM
