Outside corners to two different baseboard rooms
I have run into some difficulties installing baseboards.
I am installing white 4 1/4" decorative baseboards (no quarter-round) in our newly hard wood floored rooms. The problems is transitioning into our kitchen where there is 3" stained baseboards WITH quarter-round. Any suggestion on what to do? Would corner posts work on different sized and colored baseboards? Thank you for any tips/suggestions. |
Terminate the moulding 1 1/2" before the corner.
Make a 45% back cut, and glue in a small filler piece. The diagram would be looking down at the floor: http://i114.photobucket.com/albums/n...ekinz/Trim.jpg |
1 Attachment(s)
I am sorry, I do not get it.
Cut the two different baseboards 45 in I get. What do I put on the corner after cutting? Corner trim (see picture)? One thing I forgot to say is that the white (blue) baseboard is 8/16" while the 3" (red) brown baseboard & quarter-round is much thinner. The brown represents corner trim. |
You could install base shoe there...quarter round maybe?
Plinths/how high?
I installed 6" & 3/4" mop-boards (baseboards) made of birch in the home I just finished building. I routed a Victorian style design along the top edges, and added quarter-round along the floor edges.
I plan on cutting plinths to the bottom of each door frame (which is also birch and 3" 1/2" wide) where the baseboards meet the door frame. The plinths will also have a similar routed edge. Question: Would it be appropriate from an esthetics point of view to make the plinths taller than the baseboards, say about 1"1/2" to 2" taller? Or the same size as the baseboard. I want this to look professional, and not like it was done by an amatuer (even tho I'm slightly this side of the amatuer rating :laughing:). Nor do I want the plinths to compete with the baseboards. THNX Downdraft |
| All times are GMT -4. The time now is 08:00 PM. |
