Old 04-22-2009, 11:18 AM   #1
Outdoor Tile Project
I have successfully tiled bathrooms, kitchens, entry ways and a basement. I am considering tiling an outdoor cement slab (covered porch) and cement steps leading to the house. Both the steps and slab are more than 5 years old and have not cracks other than where the relief cuts are. This is located in S.W. PA where the winters can go well below 0 degrees and the summers occasionally get well above 90. It is covered but somewhat exposed to the elements so it will get rain and snow.
What are your suggestions for a successful install?
Rege
RegeSullivan is offline   Reply With Quote
Old 04-22-2009, 11:22 AM   #2
BIGRED
For a continued healthy, loving marriage don't use any glazed tile unless your name is Drew Peterson.
Grampa Bud is offline   Reply With Quote
Old 04-22-2009, 11:49 AM   #3
Tileguy
JazMan's Avatar
I know what you mean, but there's nothing wrong with using glazed tiles outdoors. Just not smooth and glazed.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 04-22-2009, 01:14 PM   #4
I think the question you want to ask is porcelin tile or stone? Stone will handle 0deg weather better, but is more expensive.
Rege
manjo is offline   Reply With Quote
Old 04-22-2009, 01:15 PM   #5
I think the question you want to ask is porcelain tile or stone? Stone will handle 0deg weather better, but is more expensive.
Rege
Old 04-22-2009, 01:45 PM   #6
Tileguy
JazMan's Avatar
Yes of course Manjo, he should use porcelain or a frost resistant ceramic of some type. We were not talking about that. We were talking about the finish and texture of the tiles. But your topic was going to be the next topic.
Jaz
Old 04-22-2009, 02:02 PM   #7
What type of thinset is best for outdoor use? Is there any benefit to buttering each tile or just us a notched trowel? Will water get trapped under the tile and cause it to crack and if so what can I do to minimize that problem. And, any other tips for this project would be helpful.
Rege
Old 04-22-2009, 06:33 PM   #8
Rege
I've used 6x6 quarry tile on enclosed screen porches on LI,NY. I used a modified thinset with a notched trowel. Been there for 15+ years with no ill effects due to weather. They were placed on concrete, 18-24" off the ground in each case.
Ron
Old 04-22-2009, 10:06 PM   #9
This might look good. I did a section of porcelain on a small slab - southern exposure so very hot in the summer and heavy winter weathering. It's held up well - I used thinset for stone and large tile interior/exterior. Only error was in the color of the thinset - I used white and you could see it on the leading edge of the slab.
I'm planning to do the front walk and stoop this year. Went to a real tile store this time and they actually recommended Redgard on the concrete first to help prevent moisture from rising out of the slab behind the tile.
http://www.lowes.com/lowes/lkn?actio...il=&lpage=none
Rivethead is offline   Reply With Quote
my floor refurbish project Knucklez Project Showcase 28 08-10-2010 09:14 AM
Kitchen Project Complete with pics! baksdak Project Showcase 30 03-10-2009 03:13 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
My basement finishing project DIY4EVER Project Showcase 6 02-18-2008 09:21 PM
