Outdoor Tile Heating Question - Flooring - DIY Chatroom Home Improvement Forum
Old 02-23-2008, 09:29 PM   #1
Question
Outdoor tile heating question
I live in chilly Minnesota and would like to tile my front entry area. Is it possible to use some type of electric heating mat or cable under the tile? The area is bare concrete now and about 6'x8'. Any help at all would be appreciated.
drewster is offline   Reply With Quote
Old 02-23-2008, 09:31 PM   #2
Electrician
Yes, just google it, I like easy heat or nu-heat....
chris75 is offline   Reply With Quote
Old 02-23-2008, 10:23 PM   #3
Crabby Bastard
terri_and_jj's Avatar
i have the electric mat under my tile and it works great. if you have bare concrete now it would be easy to do. i can't remember the brand i bought, but you can even get the matting at depot or lowes now
terri_and_jj is offline   Reply With Quote
Old 02-23-2008, 10:37 PM   #4
I didn't realize the stuff they sell at the box stores would be fine for outdoors in minnesota. Surprising. Thanks for the info.
Old 02-24-2008, 10:39 AM   #5
Crabby Bastard
check the manufacturers website or give them a call to make sure, but i have seen these types of systems used outdoors. ( the most common use of these products is in bathrooms, so it makes sense that you can expose to moisture) Also, make sure you have a GFCI breaker if there is not one build into the thermostat, but make sure you do one or the other. if you do both they will just constantly trip each other
Old 02-24-2008, 10:50 AM   #6
Electrician
How did you come to this conclusion?
In-Floor Heating Cable Trouble... sootybuttercup Electrical 24 12-18-2014 09:01 PM
Baseboard Heating Question RM2865E Plumbing 2 12-09-2007 09:01 PM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 07:34 PM
