Outdoor Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 01-22-2008, 04:59 PM   #1
electrician / handyman
outdoor tile
I am redoing my front porch and I allready replaced all the wood what kind f tile can I use outside in all temps and it would get wet
sethc is offline   Reply With Quote
Old 01-22-2008, 05:05 PM   #2
Rewards Points: 150
Porceline
mike costello is offline   Reply With Quote
Old 01-22-2008, 05:08 PM   #3
what type of grout
Old 01-22-2008, 09:27 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 298
Porcelain and quarry are fine. Best selections in porcelain. But, there's more to it than simply which tile or grout. You first have to have a slopped surface and an adequate framing structure. Enough plywood subfloor and a CBU made for outdoors and probably a membrane over that too.
You can start by telling us where this porch is located and answering the questions above.
Jaz
JazMan is online now   Reply With Quote
Old 01-23-2008, 08:46 AM   #5
the porch is pitched plenty and is allready water tight i was going to put down durarock then tile I just dont want anything to crack
Old 01-23-2008, 10:51 AM   #6
Tileguy
JazMan's Avatar
Rewards Points: 298
OK, I don't know what "pitched plenty" equals. You now say it's water tight, yet before you said it's a porch and is subject to all temps and will get wet. That doesn't jive.
Installing Durock isn't going to make it waterproof. You'll need to protect the plywood and the framing from moisture. Speaking of framing, can you describe how it's built and the type and thickness of the subfloor you're planning to install? How high off the ground is it? Is it well ventilated etc.
Jaz
Old 01-23-2008, 02:35 PM   #7
the structure is very strong i fixed all the beams and put down 3/4" plywood the put down tar paper the pitch is about 1/4" per foot sameas it has been for 80 years it is water tight so no water will hit plywood
Old 01-24-2008, 10:13 PM   #8
so-elitecrete
Rewards Points: 150
can't imagine anyone,,,
installing tile outdoors UNLESS there's no absolute danger of freezing temps,,, we won't even do it in ga/sc,,, unless yours is much different than most others, if its outside when it rains, it'll get wet,,, if it snows, it'll turn white, too.
others may differ but that's my story & i'm stickin' to it.
so-elitecrete is offline   Reply With Quote
