#1 |
Outdoor Dance Floor
I’m looking for ideas for a material that I can use to create a permanent outdoor dance floor. I have an existing 16’x20’ concrete slab in my back yard in west central Florida, which I would like to turn into a professional party dance floor. I originally thought about installing a wood composite deck on top of the slab. However, because it requires gaps to allow for drainage and ventilation, I rejected the idea. It would not work, because high heel dance shoes would get caught in the gaps.
It would be ideal if there were some type of material that can be applied to the surface of the slab, whether in the form of a sheet good, like vinyl flooring or applied topping, like rolled-on paint. Wood floors are perfect for dancing on, because the material gives somewhat to the pressure of walking on it. Concrete, tile, and stone are exhausting and painful to dance on for any length of time. Therefore, I would like to find something that would resemble the softer properties of wood, but without the drawbacks of its vulnerability to weather, sun, and insects. Some of the requirements are as follows: 1. Resistance to UV rays, insects, rot, and any other damage from Florida’s harsh weather elements. 2. Flat, smooth, level surface without cracks, gaps, or warping. 3. “Giving” density, so it will be easy on the feet and legs after hours of dancing. 4. Surface that will allow gliding, spinning, and turning (but not slipping) of suede-bottomed shoes. 5. Permanence and durability, to last several years of dancing and exposure to outdoor elements. 6. Wash ability with a garden hose and broom. ANY suggestions would be appreciated. Thanks. David |
#2 |
MarginallyQualified
Outdoor Dance Floor
What makes a dance floor isn't the surface... it's the structure underneath.
http://www.youtube.com/watch?v=1FvgbgTr71E http://www.facebook.com/group.php?gid=40557279801 |
| Display Modes | |
| How to repair a concrete floor we just had repaired! | timbo59 | Flooring | 11 | 01-04-2012 07:15 PM |
| First Floor Laundry Room Floor Drain install? | hammerlane | Plumbing | 9 | 10-21-2011 10:12 AM |
| Dryer duct hole thru band joist & floor joist | justplumducky | General Discussion | 12 | 10-05-2010 01:31 PM |
| 2nd floor air flow/pressure | fgillis | HVAC | 7 | 02-24-2009 05:58 AM |
| Levelling wood floor | gomi_otaku | Building & Construction | 13 | 11-27-2008 08:45 AM |
