Outdoor Carpet Over Rubber Membrane - Flooring - DIY Chatroom Home Improvement Forum
Old 04-20-2010, 12:33 PM   #1
outdoor carpet over rubber membrane
I have a 2nd story uncovered porch that has outdoor carpeting installed over a rubber membrane. The carpet needs to be replaced. What adhesive, if any, should I use? The current carpet was put down with a random bead of silicon. When the sun heats it up, the carpet wrinkles up. I'm thinking that
it's the membrane expanding. There's also a wrought iron railing that's mounted along the outer edges on top of the carpeting. Any advice?
mwhitney is offline   Reply With Quote
Old 04-20-2010, 01:57 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Welcome to the Forum
Can you post a pic?
also what is your location? (high winds, Tornado, Hurricanes?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-20-2010, 04:24 PM   #3
Thanks for the response. I'll work on getting a picture. I live in central N.C. We're not technically in a hurricane zone, but one occasionally blows through.
It gets pretty hot in the summer; highs in the 90's. We have a snow fall or two during the winter with lows typically in the 20's and 30's.
Old 04-21-2010, 10:04 AM   #4
Here are some pics
outdoor carpet over rubber membrane-hpim1530-reduced.jpg   outdoor carpet over rubber membrane-hpim1532-reduced.jpg
Old 04-21-2010, 01:23 PM   #5
Tool Geek
PaliBob's Avatar
Thanks for posting the pics
You live in a nice area
I see what you mean about the carpet.
With the railings bolted through the carpet, the only way to safely protect the membrane would IMO be to first unbolt the footing plates one by one to see if the carpet can be slid out from under.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-21-2010, 01:49 PM   #6
Thanks but I've actually already been through that part. I was the one who installed this carpet just 4 yrs ago. I'm thinking that using silicone was not a good idea. I'm inclined to not use any adhesive and just let it float, so to speak, with it held down only by the railing. I'm also thinking that I need to install a different type of carpet. I used an indoor/outdoor type of carpet before which didn't handle the moisture very well! I think this time I should use strictly an outdoor carpet; probably an all plastic material.
Old 04-21-2010, 03:02 PM   #7
Tool Geek
PaliBob's Avatar
Thanks for posting the pics.
The bolted railings will secure,
the new carpet tightly if you stretch it properly on the three outside edges. The Pics show that the carpet has pulled away from the house side, probably because any silicone adhesive is not going to perform very well in tension.
Instead of silicone the house side edge of the carpet needs IMO to be mechanically fastened to the house. When you replace the carpet you can start at that side and fold a narrow 1" strip vertically up against the house and using a long metal carpet edging strip, or angled roof flashing mechanically fasten it to the side of the house. Silicone could then be used to help seal that connection although this is not an ideal solution to prevent water intrusion.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-21-2010, 03:16 PM   #8
Thanks! One dumb question... what is IMO?
Old 04-21-2010, 04:01 PM   #9
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 112
IMO ,,,,,,In My Opinion.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rubber hoses - code compliant? daixloxbmw Plumbing 10 01-07-2011 08:15 AM
Rubber Roof Sealant ninghai Roofing/Siding 17 03-08-2010 08:58 PM
Rubber roof prices tgf40 Roofing/Siding 4 05-27-2008 01:02 PM
Portico Rubber Roof handy man88 Roofing/Siding 7 12-03-2007 02:44 AM
roof leak and EPDM membrane dbai Roofing/Siding 8 10-28-2007 05:16 PM
