Outdoor Carpet On Concrete Removal - Flooring - DIY Chatroom Home Improvement Forum
Old 05-07-2011, 11:53 AM   #1
Outdoor carpet on concrete removal
How do I remove the outdoor carpet from concrete porch when carpet backing is seperating from carpet and glue is on concrete?
carolmhd is offline   Reply With Quote
Old 05-07-2011, 05:17 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
Scrape it by hand. You can buy a 4" scraper almost anywhere.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 05-07-2011, 05:49 PM   #3
NACE Coating Inspector
mustangmike3789's Avatar
i ran into this all of the time with my decorative concrete conpany. what do you plan on doing to the concrete when you do get the glue up??? you can use a pump sprayer with xylene to soften the glue to make it easy to scrape up. just do small areas that you will be able to reach. this will get rid of the glue on the surface only it will not bring it back to new looking concrete. your other option is to rent a floor polisher with the arressive pads (black, i think?) and then step to a smoother pad. this will make the concrete smooth and it will have a slight sheen to it. this will all depend on what your future plans are with the slab. there are other options(diamond polisher) but it would help to know what you are going to do. wear a respirator and protective clothing with the xylene, not only will it remove the glue it will also remove skin and brain cells.
mustangmike3789 is offline   Reply With Quote
Old 05-07-2011, 06:15 PM   #4
Rewards Points: 12
The xylene may also keep the next flooring from sticking. That's why most pros say not to use chemical removers.
Old 05-07-2011, 06:34 PM   #5
rusty, you are right about the xylene but that is normaly when a xylene based sealer is used. straight xylene solvent isnt an issue in this case as the the solvent will sit on the surface and evaporate. we do this method on stubborn river rock removal except we will pour xylene over the surface and cover it with thin plastic to slow down the evaporation so the solvent can soften the epoxy in the riverrock. xylene sealers in a lab have been known to penetrate up to 7"-9"into concrete and that will cause a bonding issue not allowing future coatings to penetrate/bite
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Concrete in crawlspace algored2deth Building & Construction 4 05-03-2011 02:28 PM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
