Outdoor Brick Work - Flooring - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 06:36 PM   #1
outdoor brick work
Hi I live central Indiana and I plan on doing some outdoor projects this summer. I would like to put a brick patio down over an existing concrete slab. The space is only 8'x15' but I've never done brick work before and dont know what steps to take in regards to the concrete slab. Can the bricks go right over it? I'm a handyman and have been involved in construction for over 10 years. I've done some tile work before and dabbled in everything else that goes into building houses. I started remodeling homes in the summer when I was 13 for a buddies dad and haven't put a tool belt down since I currently install tele/communication cables. So I'm aware of construction methods but any advice with this issue would be grateful
EdgarF is offline   Reply With Quote
Old 03-15-2011, 08:21 PM   #2
woodman58's Avatar
If you lay the brick over the concrete you will have problems. The first and major one would be that moisture will seep in between the mortar and brick. In the winter this will freeze and thaw causing the mortar to crack and break out of the joints. Brick on a house are layed vertical. These would be layed horizotal. Leaving alot of area for moisture to collect.
But, the proper way to lay a brick patio would be to take out the concrete, leave the rock bed that is under the slab, and pour a 4" sand bed to place the brick on. Rent a vibrating tamper to pack the sand. Then lay the brick keeping them flat and at a slope away form the house. After the brick are layed, fill the gaps with sand.
If you choose to do it your way, here is a link to the best sealer on the market. (IMO)
woodman58 is offline   Reply With Quote
Old 03-16-2011, 12:02 PM   #3
Thanks for info. Moisture was my concern too.
grounding the workpiece you're welding jarnold Electrical 43 01-03-2016 07:14 PM
Issues w/ Old Work Box mkrawitz Electrical 5 04-19-2010 11:53 AM
HVAC contractor ripoff! sekntonone HVAC 8 04-05-2008 07:15 AM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 06:09 PM
