OSB Subflooring - Flooring - DIY Chatroom Home Improvement Forum
Old 11-13-2009, 03:54 PM   #1
Exclamation
OSB subflooring
I am installing hardwood.
I had particle board.
I am replacing with OSB.
I have laid 3 sheet.
I just NOTICED the printing this side down.
I have That size up.
Do I need to remove the shiny side up or will it not be an issue?
rbackmann is offline   Reply With Quote
Old 11-13-2009, 04:09 PM   #2
Rewards Points: 1,910
Particle board to me is more of a filler than a structural element so if it is really particle board you are replacing then just about anything will work.
As far as using osb structurally on floors you want to be sure and orient it lengthwise across the joists but I don't think the side up matters for hardwood underlayment.
Old 11-13-2009, 05:06 PM   #3
We pick these?
The only time that matters is when you're decking a roof. If you put the shiny side up, you or someone you work with or FOR... will end up sliding off the roof. Other than that, there are lines on some currently produced OSB sheets for helping with nailing patterns which are only marked on the rough side.
NailedIt is offline   Reply With Quote
Old 11-13-2009, 05:18 PM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
r, Welcome to the Forum
It doesn't make any difference from a structural standpoint. However if the OSB has tongue & groove edges then all the panels have to be laid with the same side up or down as the case may be so that the profile grooves will match.
Answers to some general OSB floor sheathing questions:
http://osbguide.tecotested.com/faq16
and some OSB FAQ
http://osbguide.tecotested.com/osbfaqs
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-13-2009, 06:09 PM   #5
Registered User
Rewards Points: 5,256
I don't know if it makes a difference structurally. 1. The installation instructions that PaliBob sited say "label down" -- so you will be voiding the warranty. 2. In construction the Building Inspector checks for the visible label, up at the roof and second floor for the rating and span listed per application. The colored layout lines also tell an inspector the framer installed a half sheet with the strength axis wrong if he sees them running perpendicular to the trusses/rafters from below. The waxed side is from manufacturing for easy release from the press.
Be safe, Gary
Old 11-14-2009, 05:07 AM   #6
Tool Geek
PaliBob's Avatar
Originally Posted by GBR in WA View Post
........ The waxed side is from manufacturing for easy release from the press. Be safe, Gary
Wow, Thanks Gary, I wondered why one side was waxed.
I cribbed my "Don't Matter" response in post #4 from Tommy @TOH
http://www.thisoldhouse.com/toh/askt...430695,00.html
Disclaimer
& Stay Safe
.....Bob Lavery
replacing subflooring in pier & beam michellejasper Flooring 1 11-03-2008 08:12 PM
recommended subflooring for hardwood on concrete slab blackcat Flooring 5 10-26-2008 06:15 PM
Flooring vs Subflooring (whatever it is called) lifeontherun Flooring 3 07-13-2008 04:03 PM
Flooring vs Subflooring or whatever it is called lifeontherun Flooring 10 07-09-2008 09:14 PM
House with hardwood and no subflooring onyx_asylum Flooring 1 02-25-2007 09:52 PM
