OSB + Plywood = Solid Base For Tiling? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-16-2012, 08:13 PM   #16
Ok, thanks a lot and I will use powdered thin set.
And last question, I have number of screws driven into the joists through the plywood and subfloor OSB, I can still remove them before I install cement boards. Should I leave them or should I remove them?
I have seen different comments on different websites. Some say you never screw into joists and some say you have to.
Last edited by Denisrus; 05-16-2012 at 08:20 PM. Reason: forgor to ask the question
Denisrus is offline   Reply With Quote
Old 05-16-2012, 08:21 PM   #17
DIY staff
Rewards Points: 7,174
The Schluter or Latacrete membranes work very well and only add 1/8" --tried and true method--so you have the choice Ditra or Wonder board--
Denisrus (05-16-2012)
Old 05-16-2012, 08:59 PM   #18
Please never mind about screws driven into joists, I will remove them.
Old 05-16-2012, 09:08 PM   #19
DIY staff
I use a roofing gun and roofing nails--those screws are slow to install---and pricey and the heads sometimes protrude--
Mesh the seams as you install the tile--this avoids the possibility of having a hump---
Old 05-16-2012, 09:30 PM   #20
Pro
JetSwet's Avatar
Rewards Points: 502
Tussah mike 1 1/2 hot dipped galvanized roofing nails, if the op has the equipment then all for it!
JetSwet is offline   Reply With Quote
Old 05-16-2012, 10:00 PM   #21
Tileguy
JazMan's Avatar
Rewards Points: 346
Hi all,
Too late now, but that is not the recommended type of ply there. That is the cheapo stuff looks like. I know you said you can't read the stamp, but what does your receipt say? Just for info at this stage.
Never use 1/2" trowel for the thin set under any CBU. Where did that come from? !/4x1/4x1/4 is the right one, and make the thin set a little thinner than normal. I recommend Ditra though, so make sure you get both types of thin set. Ditra will save you a little over 1/8", so you will be at about 1 1/4" higher than the subfloor.
Acrylpro is bad stuff, plus you get to pay 3-4 times more than the right stuff which comes only in a bag.
Jaz
Old 05-16-2012, 10:24 PM   #22
the receipt says: 4x8-3/4 SPRU <A>
Ditra would be too expensive for just one bathroom, I will only use 50% of the roll and will pay $150 CAD.
I will have to go with cement boards.
Old 05-16-2012, 10:34 PM   #23
Tileguy
JazMan's Avatar
Rewards Points: 346
OK, not enough info on the receipt. It doesn't matter now, but you can check it out next time you're at the lumber yard.
Yes the small roll is only 54 ft. but too much for you. $1.50 a sq. ft. is a good price. Concrete board will work just fine for you. It's just gonna raise the floor another 3/16" and waterproofing isn't a big issue for you.
Jaz
Old 05-16-2012, 10:47 PM   #24
I will be using Versabond fortified mortar as I already have it, used it for Durock panels seams on the walls. I have read a lot here that is not the best stuff but still would work (will NEVER, NEVER ask Home Depot guys for advice). The only problem is, it is grey and I am planning to use white grout. Would it work?
Old 05-16-2012, 10:52 PM   #25
DIY staff
Spend the money on some white---some of the thinset will squeeze up and need to be removed--Gray will work,but you will spend more time than you like removing the gray squeeze up than you like--
Old 05-16-2012, 10:56 PM   #26
Tileguy
JazMan's Avatar
Rewards Points: 346
Gray will work, just be sure to keep the joints clean. How old is that opened bag of gray Versa? What kind and size tiles will you be using?
Now you're learning. But that's the best reason to not give them any of your $$$. They don't care to hire people that know stuff.
Jaz
Old 05-16-2012, 11:48 PM   #27
The bag was opened maybe for a month but I wrapped it in garbage bag, so it was sealed.
Ceramic tiles, 13x13.
Old 05-17-2012, 09:57 AM   #28
I have got another problem - toilet installation. If I rise the floor by 1 1/2", I don't think I can find proper wax ring, I have to go to the plumbing section in this forum.
Old 05-17-2012, 12:22 PM   #29
Pro
JetSwet's Avatar
Rewards Points: 502
You can find a wax ring with a plastic ring end on it the name escapes me now but they are for this reason. HD carries them.
Old 05-17-2012, 12:54 PM   #30
Well, I know I can but those, but for such a big step in flooring height I would have to put two wax rings on top of each other. I used flange extension rings one day and they leaked, I dont know if I did something wrong. In my other bathroom the plumber used two wax rings but now I will go even higher.
Did anybody try to remove glued plywood (to OSB)? I am thinking now to rip it and put exterior grade 1/2", then I will not have that many issues.
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 02:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 05:08 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
Removing solid shower base with marble chips WoozyChain Plumbing 2 08-15-2009 07:10 AM
How to create a curved wooden base shoe? hayzen Carpentry 3 07-28-2009 03:29 PM
