OSB + Plywood = Solid Base For Tiling? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-16-2012, 01:26 AM   #1
Question
OSB + Plywood = solid base for tiling?
I know it's kind of old topic but...
I have 19/32" OSB subfloor, on top of it I put 3/4" plywood. I used glue and hundreds of screws to build proper base for tiling the floor in one of my bathrooms. I did the same in the other one and now it's been over a year, no cracks, the floor is solid. My bathrooms are fairly small and require one or less than one sheet of plywood. I used Acrylpro ceramic tile adhesive from Home depot. Later I read a lot about tiling over plywood and now I am really concerned about it, plus the plywood I used is not exterior grade.
Should I do the same in the second bathroom? I don't think its a good idea to rip off the plywood as it is glued and screwed to the subfloor.
I am just about to start tiling and have all tiles precut and ready to be installed. Do you have any ideas on what I should do?
Thanks a lot!
Denisrus is offline   Reply With Quote
Old 05-16-2012, 11:11 AM   #2
Remodeling Contractor
Sub floor is fine, but add 1/4" cement board. Do not tile over plywood!
Old 05-16-2012, 11:15 AM   #3
Rewards Points: 13,690
It should have been 3/4" subfloor rated, which would be ext. glue and no voids.
When adding underlament it does not get glued, just screwed.
There needs to be a thinn set under the 1/4 tile board spread out with a 1/2" toothed trowl.
It serves to fill in the small voids in the low areas between the floor joist.
Old 05-16-2012, 04:07 PM   #4
1/2" toothed trowel sound too big to me. Would it be just enough to level the floor with a flat side of a trowel to fill the voids?
Once I set thin set, I can intall 1/4" Hardi-Backer board right away, can't I?
Do I have to use special type screws?
How long does it take before I can start installing tiles?
Old 05-16-2012, 06:10 PM   #5
Pro
JetSwet's Avatar
Rewards Points: 502
What type of 3/4 ply did you put down? Joe is right about the 1/2" for tile board. Are you going with the cement board or are you going to tile on the ply?
JetSwet is offline   Reply With Quote
Old 05-16-2012, 06:21 PM   #6
typing mistake
Last edited by Denisrus; 05-16-2012 at 06:32 PM. Reason: i have posted three times
Old 05-16-2012, 06:22 PM   #7
typing mistake
Last edited by Denisrus; 05-16-2012 at 06:34 PM. Reason: posted the same three times
Old 05-16-2012, 06:23 PM   #8
I have 3/4", non exterior grade. I looked up in hardie backer instructions and they say a 1/4" trowel should be used. But they also say the plywood should be exterior grade.
I will put 1/4" cement board and then tile.
Old 05-16-2012, 06:35 PM   #9
DIY staff
Rewards Points: 7,174
Okay, everyone--reread his (her) post---
The glue is not needed between the OSB and the plywood---
You may have used exterior glued ply--it should have a grade stamp that will say something like"
3/4" BC
exposure 1. (exterior glue)
Or "3/4" CDX" (X + exterior)
Next--the 1/4" Cement board--1/4" trowel is fine-(I often use 1/4 x3/8)-set into a bed of fresh modified thinset--Then nailed with roofing nails or screwed with alkali resistant screws.
Last --the mud you used--wrong stuff,if I am not mistaken,Isn't AcriliPro a premixed mastic?
Should be a powdered modified thinset---
Mastics are water soluable and will re emulsify when exposed to water--(leaking toilet--shower curtain loose--)
Also--mastic needs air to dry ---with a big old tile covering the wet mastic,this could take months.
Ceramic tile can be set over exterior grade ply when using a good powdered thinset--
While not the ideal surface like Durock or Wonder Board--it will work most of the time---Mike---
Old 05-16-2012, 07:07 PM   #10
Pro
JetSwet's Avatar
Rewards Points: 502
The op can tile right over sanded cdx or sanded Bc ply although not recommended by most here.
The Following User Says Thank You to JetSwet For This Useful Post:
oh'mike (05-16-2012)
Old 05-16-2012, 07:44 PM   #11
Well, I can't see stamp on ply wood of any kind of grade, maybe on the other side?!?
AcrylPro is premixed mastic.
I will install 1/4" hardiebacker and then tile, however my floor willl be at least 1 1/2" above the subfloor. Plywood 3/4" + cement board 1/4" + tile 1/4" + thin set x 2 = approx 1 1/2".
I will have to come up with some way to have a transition between hardwood and bathroom floor.
Old 05-16-2012, 07:48 PM   #12
Is it normal to have such a bathroom floor to subfloor difference (1 1/2")?
Old 05-16-2012, 07:53 PM   #13
Would Ditra or Schluter membrane do the same as cement boards?
Old 05-16-2012, 08:00 PM   #14
DIY staff
It's not uncommon--you went a little over the top with 3/4" ply--1/2" would have been fine--
That ply looks like BC exposure one,by the way--so you do have exterior ply--
A wood reducer at the door will give you a nice look--If you have a table saw and a router you could make a custom one that will be the same thickness as the tile--
Please use a powdered modified thinset---the premixed bucket mixes often cause trouble--and thinset is less expensive---Mike--
JetSwet (05-16-2012)
Old 05-16-2012, 08:03 PM   #15
Pro
JetSwet's Avatar
Rewards Points: 502
Well so much for your pattern that was marked out, that looks like unsanded ply to me to many knot holes.
Since your questioning the hight use 1/4" trowel so it's not that high when u place the cement board.
Screw your boards with backer on screws and mesh tape the seams with thinset.
A Marble saddle for door is what you will need.
Denisrus (05-16-2012)
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 02:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 05:08 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
Removing solid shower base with marble chips WoozyChain Plumbing 2 08-15-2009 07:10 AM
How to create a curved wooden base shoe? hayzen Carpentry 3 07-28-2009 03:29 PM
