-   -   OSB + Plywood = solid base for tiling? (http://www.diychatroom.com/f5/osb-plywood-solid-base-tiling-143921/)
Denisrus 05-16-2012 01:26 AM
I know it's kind of old topic but...
I have 19/32" OSB subfloor, on top of it I put 3/4" plywood. I used glue and hundreds of screws to build proper base for tiling the floor in one of my bathrooms. I did the same in the other one and now it's been over a year, no cracks, the floor is solid. My bathrooms are fairly small and require one or less than one sheet of plywood. I used Acrylpro ceramic tile adhesive from Home depot. Later I read a lot about tiling over plywood and now I am really concerned about it, plus the plywood I used is not exterior grade.
Should I do the same in the second bathroom? I don't think its a good idea to rip off the plywood as it is glued and screwed to the subfloor.
I am just about to start tiling and have all tiles precut and ready to be installed. Do you have any ideas on what I should do?
Thanks a lot!
Bob Mariani 05-16-2012 11:11 AM
Sub floor is fine, but add 1/4" cement board. Do not tile over plywood!
joecaption 05-16-2012 11:15 AM
It should have been 3/4" subfloor rated, which would be ext. glue and no voids.
When adding underlament it does not get glued, just screwed.
There needs to be a thinn set under the 1/4 tile board spread out with a 1/2" toothed trowl.
It serves to fill in the small voids in the low areas between the floor joist.
Denisrus 05-16-2012 04:07 PM
1/2" toothed trowel sound too big to me. Would it be just enough to level the floor with a flat side of a trowel to fill the voids?
Once I set thin set, I can intall 1/4" Hardi-Backer board right away, can't I?
Do I have to use special type screws?
How long does it take before I can start installing tiles?
JetSwet 05-16-2012 06:10 PM
What type of 3/4 ply did you put down? Joe is right about the 1/2" for tile board. Are you going with the cement board or are you going to tile on the ply?
Denisrus 05-16-2012 06:21 PM
typing mistake
Denisrus 05-16-2012 06:22 PM
typing mistake
Denisrus 05-16-2012 06:23 PM
I have 3/4", non exterior grade. I looked up in hardie backer instructions and they say a 1/4" trowel should be used. But they also say the plywood should be exterior grade.
I will put 1/4" cement board and then tile.
oh'mike 05-16-2012 06:35 PM
Okay, everyone--reread his (her) post---
The glue is not needed between the OSB and the plywood---
You may have used exterior glued ply--it should have a grade stamp that will say something like"
3/4" BC
exposure 1. (exterior glue)
Or "3/4" CDX" (X + exterior)
Next--the 1/4" Cement board--1/4" trowel is fine-(I often use 1/4 x3/8)-set into a bed of fresh modified thinset--Then nailed with roofing nails or screwed with alkali resistant screws.
Last --the mud you used--wrong stuff,if I am not mistaken,Isn't AcriliPro a premixed mastic?
Should be a powdered modified thinset---
Mastics are water soluable and will re emulsify when exposed to water--(leaking toilet--shower curtain loose--)
Also--mastic needs air to dry ---with a big old tile covering the wet mastic,this could take months.
Ceramic tile can be set over exterior grade ply when using a good powdered thinset--
While not the ideal surface like Durock or Wonder Board--it will work most of the time---Mike---
JetSwet 05-16-2012 07:07 PM
The op can tile right over sanded cdx or sanded Bc ply although not recommended by most here.
Denisrus 05-16-2012 07:44 PM
1 Attachment(s)
Well, I can't see stamp on ply wood of any kind of grade, maybe on the other side?!?
AcrylPro is premixed mastic.
I will install 1/4" hardiebacker and then tile, however my floor willl be at least 1 1/2" above the subfloor. Plywood 3/4" + cement board 1/4" + tile 1/4" + thin set x 2 = approx 1 1/2".
I will have to come up with some way to have a transition between hardwood and bathroom floor.
Denisrus 05-16-2012 07:48 PM
Is it normal to have such a bathroom floor to subfloor difference (1 1/2")?
Denisrus 05-16-2012 07:53 PM
Would Ditra or Schluter membrane do the same as cement boards?
oh'mike 05-16-2012 08:00 PM
It's not uncommon--you went a little over the top with 3/4" ply--1/2" would have been fine--
That ply looks like BC exposure one,by the way--so you do have exterior ply--
A wood reducer at the door will give you a nice look--If you have a table saw and a router you could make a custom one that will be the same thickness as the tile--
Please use a powdered modified thinset---the premixed bucket mixes often cause trouble--and thinset is less expensive---Mike--
JetSwet 05-16-2012 08:03 PM
Well so much for your pattern that was marked out, that looks like unsanded ply to me to many knot holes.
Since your questioning the hight use 1/4" trowel so it's not that high when u place the cement board.
Screw your boards with backer on screws and mesh tape the seams with thinset.
A Marble saddle for door is what you will need.
