Old 03-27-2011, 08:53 PM   #1
OSB or plywood? Glue or no glue?
Tomorrow I am starting my LR flooring project. Floor has to come out clear down to the foundation unfortunately. We have already purchased peel and stick tile that looks like wood to put down in the room. (This is an old cabin so not looking for fancy). I have 2 questions....
1. Do I use OSB or plywood and at what thicknesses?
2. The tile is peel and stick but should I add some sort of "glue" on the floor to help them stick better? If so please tell me exactly what that "glue" would be called
Thanks so much!
Marilyn
Truckerswife is offline   Reply With Quote
Old 03-27-2011, 09:09 PM   #2
Learning by Doing
Leah Frances's Avatar
I bet the manufacturer of the 'tiles' has some instructions or specs that would help....
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-27-2011, 09:23 PM   #3
Tileguy
JazMan's Avatar
Hi Marilyn,
What does that mean?
Plywood, no OSB. What thickness I don't know until you give more info.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 03-27-2011, 09:25 PM   #4
woodman58's Avatar
What ever you use, OSB or ply you need to put luan or a sanded ply down and fill the nail/staples and seams. You can use a product called Thin Spread to glue the peel and stick tile. Make sure and use the right size trowel and read the directions. After the glue is set starting with one corner and work the tile flush with the tile next to it. With the 2 glues it is very hard to move the tile once they are in place.
woodman58 is offline   Reply With Quote
Old 03-27-2011, 09:52 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Do not just start in a corner. You could end up with a piece on the other wall an inch wide. You measure the width and split the difference. You need to chalk line a square line so you can stay straight.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 03-27-2011, 10:11 PM   #6
A bit of explanation of the flooring issue....
Originally the cabin was just two rooms. At the area where someone added onto it years ago there doesn't seem to be proper support. The floor in the old part and the newer part both seem sturdy but where the two areas meet the floor is low, soft, and if I bounced hard enough I am pretty sure I'd fall through and I'm not a big woman. It doesn't feel rotten it just feels like it's not supported properly. From the highest point to the lowest (new area versus old) there is a difference of 1 3/4 inches over an area 6 ft long and about 2 feet wide. The older portion is OSB and the newer is plywood. Where the OSB is I can see that there are several layers of it. It honestly feels like possibly the OSB and plywood may be butted up against one another but not attached to anything underneath. Guess I will find out the real issue tomorrow when I open up the floor.
Thanks for the suggestions thus far.
Old 03-27-2011, 10:26 PM   #7
I just realized I could attach a link to photos. I hope I am doing this right. Here is the floor in question loaded into a Webshots album.
http://community.webshots.com/album/579969612SyWhJs
Old 03-27-2011, 10:30 PM   #8
And I should have mentioned that the white area you see in the photo is spray foam that I used to fill the gap between the two levels of flooring.
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 06:08 PM
do i have to remove old adhesive glue on wall for new ceramic with glue? Limit54 Tiling, ceramics, marble 2 03-01-2010 11:12 PM
Best glue for plywood laminate? cvriv.charles Building & Construction 2 07-13-2009 10:03 PM
Kitchen plywood countertop glue? ohman Flooring 5 06-24-2009 02:52 PM
Expand/Contract: Glue & screw 7" x 3/4" OSB strips on top of 3/4 plywood subfloor ? iMisspell General Discussion 8 05-11-2009 08:09 PM
