Original Hardwoord Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 03-30-2013, 07:56 PM   #1
Original hardwoord floor
My house was built in 1900, we would like to maybe rip up the carpet in our dining room and living room and use the original hardwood floors. The dining room currently has two layers of carpet over the wood floor. A plush carpet (not plush anymore) was installed by the previous owners in 1985 and orange shag carpet by the owners before that in 1972. The pine wood floor is underneath that and the tongue and groove floor boards are nailed directly to the studs. Would it be energy efficient to use these hardwood floors and how would we go about restoring them? The floor is not currently insulated in the basement underneath.
Original hardwoord floor-img_1333.jpg   Original hardwoord floor-img_1334.jpg   Original hardwoord floor-img_1335.jpg
awl98 is offline   Reply With Quote
Old 03-30-2013, 08:00 PM   #2
Rewards Points: 13,724
Need to see how bad the floor is from the top side.
Unless you insulate and air seal that floor from below all the cold air from the basement and odors will be drawn into the room above.
Old 03-30-2013, 08:05 PM   #3
When we moved here 25 years ago we replaced the carpet in the living room, we saw the floor then and it was in good shape except around heating ducts were I guess they used to have a coal furnace and the vents were bigger, then downsized when forced air was installed in 1972. They used plywood to fill in around the new vents. We have never ripped up the carpet in the dining room yet but I would assume thats its the same as the living room.
Old 03-30-2013, 08:10 PM   #4
If it's been cut up and patched it's time for plan B.
Prefinished hardwood, engineered flooring real hardwood.
Still would have to go back and add ceramic coated decking screws to stop the old flooring from moving.
Floor joist replacement and reconfiguration WillK Carpentry 2 09-01-2011 08:01 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Moving original hardwood floor stubits Flooring 1 11-04-2009 08:18 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
second floor addition without removing original roof coralhead1 Building & Construction 8 10-06-2006 05:56 AM
