-   -   Options for resurfacing over old cutback adhesive (http://www.diychatroom.com/f5/options-resurfacing-over-old-cutback-adhesive-21999/)
burlis 06-09-2008 03:42 AM
Ok, In my basement wash room there is old cutback residue that I'm assuming once had tiles over top of it. I'm assuming the old adhesive contains asbestos. :(
I'm looking for the simplest and easiest solution for this floor possible. Ideally, I want to put down expoxy floor finish over the area. I don't want anymore tile, flooring, etc. My question is whether I can use the epoxy floor coat directly over the thin residue or do I have to apply a thin layer of something else first. :huh:
I have a blue bag of quikrete concrete resurfacer I purchased at lowes: http://www.quikrete.com/ProductLines...Resurfacer.asp
I'm thinking about putting this on the cutback before the epoxy coat, but I'm not sure if it will adhere to the cutback or not? Is there something I can add to the resurfacer to ensure adhesion?
Is there better product/method I can use to seal/level the floor before applying teh epoxy? If so, I would prefer to order it through lowes since I live very close. I'm planning to call quikcrete tommarrow and see what they recommend. Basically, I just want the fewest steps to apply the epoxy coat. Do I just need to wet scrape the cutback to a very thin stain and apply a sealer before the epoxy? I need a solution for this problem. Any suggestions would be most appreciated. Thanks. :)
burlis 06-11-2008 03:35 AM
Anyone out there?
Ok I called quikrete and none of there products will works unless floor is pressure washed/shot blasted lol!
In this day and age I know there is a floor topping that will stick to to some old adhesive residue. Don't say no there isn't either because I know there are some tough cement mixes out there. Just look at the floor at your local lowes/home depot, what is that crap? I guess it's some big secret secret. Whatever it is it sure as hell isn't "popping" off anywhere and I don't think it gives a damn if it's legally married to what it was put over either.
Does anyone even look at posts to this forum?:huh:
