Options For Cold Basement Concrete Floor? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-09-2009, 12:05 PM   #16
thanks but it doesn't look like it can be cut to fit all shapes of rooms.do you order it in specific layouts for each room
ghopper57 is offline   Reply With Quote
Old 12-09-2009, 12:23 PM   #17
Get out of the box!
Rewards Points: 260
It comes in varity of sizes, they will coordinate with any room size.
We like to see layouts and then help the customer decide what works the best.
The mats you viewed are the most energyminded on the market. The ribbon gives a lower profile than the cable and since it is thicker in width provides a better heat transfer at a lower wattage rate.
The cost is 1/3 less of most other styles of less efficient mats.
Schluters Kerdi Shower System, Ditra. Loxcreens ProVa Mat Shower Systems
Konecto Luxury Vinyl Plank,Armstrong and Hardwood flooring.
https://IndianaFloorsLLC.com/default.aspx
26yrsinflooring is offline   Reply With Quote
Damp Concrete Garage Floor Tom S. Building & Construction 15 03-27-2010 08:23 AM
Best way to clean rough basement concrete floor Red Squirrel Flooring 3 09-21-2009 06:47 AM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
roofing tar on basement concrete floor? bluebee1314 Flooring 3 11-05-2007 06:19 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
