-   -   Opinions: Pre Attached Underlayment? (http://www.diychatroom.com/f5/opinions-pre-attached-underlayment-125347/)
braves22 12-02-2011 12:56 PM
Guys,
I'm ready to tackle my first flooring job and everyone has been a BIG help around here for other things so I thought I'd ask...
I found a AC3 rated Tarkett laminate floor that I liked and was curious as to what some think about whether to buy flooring w pre attached Underlayment or do the underlay separately...
I noticed (obviously) at Lumber Liq that there are some cheapies you can buy w/o the underlay but they become just as pricey when you add the underlay in...
I'm not wanting to go super cheap but it is on a budget and the Tarkett I found at 9mm has the preattached underlay of 3mm and for 350 sq ft it's under $500...
So, best deal for the money?
And is preattached the way to go?
Btw this is for a 17x15 living room and a 23x3 hallway...
Thanks!
joecaption 12-02-2011 01:01 PM
There is no flooring with preattached subflooring. There maybe a backing to act as a vaper barrier.
Subflooring would be at least 3/4 thick in 4' X 8' sheets and gets installed on top of the floor joist, then underlaymet goes down, then the flooring.
braves22 12-02-2011 01:05 PM
It says pre attached underlayment...so yes that's what I'm asking...
Opinions on whether ppl like it and whether it's a good option to go with
joecaption 12-02-2011 01:16 PM
It works fine. Faster and neater then having to lay down and tape foam.
poppameth 12-03-2011 09:38 AM
The pad on the pre-attached is usually not as good as some of the separate pads you can get. It depends on what you are comparing it to. You can put down a sheet of 6mil plastic before installing laminate with a pad attached to act as a vapor barrier if you need it. This would only be needed below grade or on a concrete slab generally. Personally I wouldn't touch Tarkett laminate. We sold it for a while and every few years they kept redoing the line because it was so problematic, whether it was finish problems or installation problems. They have a terrible track record for laminate.
rusty baker 12-03-2011 10:30 AM
And be careful with LL. They have a poor record with the quality of their products and customer service.
braves22 12-03-2011 11:12 AM
So who would you guys recommend for a reasonably priced laminate w an attached underlay?
And what would you recommend?
braves22 12-03-2011 06:35 PM
What are the thoughts on Mohawk, Pergo Prestige, and Home Legend?
Plan on making my purchase by end of weekend and it's down to those 3 now.
Thanks.
poppameth 12-04-2011 11:17 AM
Pergo has taken a big quality drop the last few years. I haven't tried Home Legend. Mohawk should basically be Quickstep since they own the Quickstep brand. I'd look at real Quickstep if you can. Most of the products are on a manufacturer's sale through the end of the year. Hopefully someone near you is taking advantage of that and actually running a promotion on it. You can get a good grade of it for $2-$3 / SF on sale pricing.
braves22 12-04-2011 08:57 PM
So what do you think about buying from Lowe's or Menards?
They seem to have the best selection of Mohawk and Quickstep...
Is there anything else in particular I should be looking for besides the AC rating?
poppameth 12-05-2011 05:50 AM
You want a minimum 7mm product, preferably 8mm or above. Anything thinner will give you issues with installation, and Lowes definitely has thinner junk.
braves22 12-06-2011 02:36 PM
You guys know much about Mannington?
I have liked a few of their items and they look to be put together well
