Opinions On This Kitchen Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 09-14-2009, 11:05 PM   #1
Opinions on this kitchen floor
I would like to level this concrete floor for ceramic tile, in this kitchen. Its for an apartment that I'll be renting out. Now, I know the concrete is not in good shape. I've enclosed some pics to give ya an idea of what this looks like. I plan on putting the tile right over the concrete.
If this is not possible, what other types of floors would you guys recommend for an apartment kitchen floor. The floor is 132 square feet.
One more thing, the wetness you see in the pics is from me cleaning. Now, the previous owners did not take any care of this floor and allowed the sink to leak, which in turn rotted out the plywood. Thats why I tore it all apart.
Opinions on this kitchen floor-img_0299-trim.jpg   Opinions on this kitchen floor-img_0300-trim.jpg
vetteroof is offline   Reply With Quote
Old 09-14-2009, 11:11 PM   #2
another pic. I have more, if you need to see them. If tile is not possible, what other options would you do?
Old 09-15-2009, 09:43 AM   #3
WaldenL's Avatar
Rewards Points: 268
Is that the foundation slab, or some other concrete? How thick is that concrete, and what's under it?
WaldenL is offline   Reply With Quote
Old 09-15-2009, 09:20 PM   #4
Remodeler
MinConst's Avatar
Your asking a bit much with these pictures. I would recommend you call a tile guy in to look it over. If you want to DIY pay him for his consult of need be.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 09-16-2009, 06:40 AM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
It looks like a couple of the sleepers are cut with a taper on the end. Is that sloped concrete at the wall poured into the floor, or something that was added on top?
Old 09-16-2009, 11:52 AM   #6
WaldenL's Avatar
Rewards Points: 268
Laminate is another option. Yes, you have a water problem, but it's a fraction of the cost of tile. But the cheap (but still quite nice looking) 10mm stuff in BJs Club (7mm laminate w/integrated 3mm padding) and you can do 132 SF for < $150. Tile will be _much_ more.
Old 09-17-2009, 09:50 PM   #7
floor
You need to figure out how to fix the water issue before adding the floor. It could be as easy as regrading the yard and extending the downspouts so they don't let water pool around the foundation. Not sure what is on the outside of the area you have pictures, so it's hard to tell.
Here's more on that -- hopefully it's a quick fix! http://www.oldhouseweb.com/how-to-ad...basement.shtml
Allison1888 is offline   Reply With Quote
kitchen floor advice Grumpy Flooring 4 03-21-2011 04:34 AM
lay travertine floor or install kitchen cabinets first? palacenil Flooring 31 07-28-2010 10:42 PM
Hardwood floor questions (56K) ukrainetz Flooring 1 08-02-2009 01:08 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
tiling kitchen...how to deal with electrical outlets in floor? tarheelblue Electrical 4 01-29-2008 10:40 PM
