Opinion Wanted, Does This Need To Be Re Done? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-21-2009, 06:38 PM   #1
Opinion wanted, does this need to be re done?
Hello, I'd like opinions on this section of our hardwood floors. I have attached pics to show the issue. Our house was built in 2005, we moved in that fall. After moving in, we had this issue in the exact same spot, and the floor contractor came out in spring of 2007, and replaced the section of flooring highlighted in the first pic, due to the boards splitting in the EXACT same spot. See the arrow? thats where the splits are the worst, but they basically are happening all along this door area. So they re-did this whole section, and boom, 2 more winters and look at it, it's splitting about as bad as the first time.
My question is, should I just fill in these huge splits with wood filler, or call the flooring contractor back out? Or is this issue in, or around the door frame? There is no leaking that I can see outright. Any input much appreciated!
The area between the black lines is what was replaced in spring 2007
The below shots are what the area looks like now. These shots are pointed right where the arrow is in the top pic.
dtmbizzle is offline   Reply With Quote
Old 02-21-2009, 06:44 PM   #2
Floorwizard's Avatar
What is the level of humidity in the home?
Is it kept constant?
Floorwizard is offline   Reply With Quote
Old 02-21-2009, 07:02 PM   #3
Were in Denver, CO so it's real dry here in the winter, we have a humidity control in the basement, and I keep it at the recommended level, about 20%. We open the doors windows in the summer, so it gets more air for those months. I know for a fact that it's been dryer in here this winter, because the rest of the ground floor is pretty much all the same hard wood, and we've had a TON of snap, crackle and pop this winter compared to last. I just put the humidity control up a wee bit.
Old 02-21-2009, 07:47 PM   #4
General Contractor
HWConstruction's Avatar
Run your humidity between 30-40%. Looking at the pictures, to me it looks like a door issue. The molding at the bottom of the door looks to have been wet. It wouldn't be the first time i've seen a door leak like this.
HWConstruction is offline   Reply With Quote
Old 02-21-2009, 08:00 PM   #5
Is this your main enterance? If so your problem is why most foyer are tile/linolium you may need to consider that option
jaymaniam is offline   Reply With Quote
Old 02-21-2009, 08:11 PM   #6
That's recommended?
Sounds low to me-
Old 02-21-2009, 08:32 PM   #7
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 48
Put a level on the floor. See if it is settling.
rusty baker is online now   Reply With Quote
Old 02-21-2009, 10:00 PM   #8
It's not the main entrance, but its where we go out to the grill. It's opened pretty frequently.
Old 02-21-2009, 10:03 PM   #9
Originally Posted by Floorwizard View Post
That's recommended?
Sounds low to me-
The control unit does it by temperature. If it's below 20 degrees it says keep it at 20%. I agree with you, I am going to keep the humidity setting higher from now on.
Old 02-21-2009, 10:19 PM   #10
Sounds like you need to up the humidity a little. It also looks like one of the boards has separated a little as well. More humidity and see how that works.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Wanted: Second opinion on radiant floor/boiler hookup drh HVAC 4 01-16-2010 09:41 PM
Opinion needed about changing kitchen faucet chris_p Plumbing 11 02-01-2009 11:39 PM
Where to run the line...opinion wanted Scottz Electrical 4 10-22-2007 06:41 PM
What is your opinion on Goodman units? TomClarkInLubbock HVAC 3 08-16-2007 06:38 PM
