Open Wood Steps Need Carpet? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-20-2012, 12:30 PM   #1
Open wood steps need carpet?
I have an open staircase. The previous owner wrapped carpet around each step. I would like to avoid doing this again. Can I just sand and poly the wood steps or is this a bad idea? It is a rental unit with the stairs leading to the bedrooms.
PVGUTTER is offline   Reply With Quote
Old 06-20-2012, 03:50 PM   #2
If you have solid wood under the steps I would definitely refinish them. They will hold up much better than carpet in a rental and in my opinion look much better. I would rent an edge sander from your local tool rental shop, it will make it much easier to do.
RhodesHardwood is offline   Reply With Quote
carpet to wood flooring change gonzokat Flooring 3 12-03-2011 11:54 PM
Carpet cleaning - sump water n0c7 Flooring 17 08-29-2011 07:04 AM
Bathroom perimeter joints: just leave 1/4" open on perimeter if wood trim will hide? lazzlazz Tiling, ceramics, marble 0 04-23-2010 03:01 PM
Wood floor or carpet? darsunt Flooring 9 08-03-2007 11:12 PM
