Old 11-22-2011, 06:10 AM   #1
Only a few SqFt needed of hardwood floor
Hi, I used HomeLegends engineer hardwood floor for my babys room. The room is 120Sq ft so I ordered 5 boxes of 25sq ft each, total of 125sq ft. For some reason the 125sq ft of hardwood floor was not enough, I need another 12sq ft or about 7 to 9 boards/planks. The box cost me $75 each (at home depot), I really don't want to buy another box and use less than half. I email home legend but I have not get a reply, does any of you know if there is a place were I can buy hard wood floors by the board/plank? Thx
eosandov is offline   Reply With Quote
Old 11-22-2011, 06:37 AM   #2
Super Moderator
you want the same lot number so the color will match----buy another box.
Old 11-22-2011, 01:31 PM   #3
Your only option is to probably buy another box. You could maybe try posting an ad in the wanted section of craigslist, but it is probably pretty unlikely that you would find it.
RhodesHardwood is offline   Reply With Quote
Old 11-22-2011, 11:19 PM   #4
I really don't mind if they are different a color as long as they are smilar, this are for the closet. I guess I am going to have to use something else in the closet. Thank you very much.
Old 11-23-2011, 07:20 AM   #5
Super Moderator
You need 1/2 of a box to complete the job correctly ----and add value to your home--
Can I glue down an Armstrong locking hardwood floor? Fixitgeorge Flooring 10 01-30-2013 12:49 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 06:15 AM
Hardwood Floor Buckling klappjack Flooring 2 06-06-2011 09:56 AM
hardwood floor transition from old to new cooter Flooring 4 05-25-2009 11:20 AM
Hardwood floor duct opening repair gshock Carpentry 4 07-29-2007 12:57 AM
