Old 02-15-2007, 04:29 AM   #1
Default old uneven bathroom floor
Hello all
I am in the process of redoing my very old house. I am ready to finish up a bathroom I recently gutted. The floor is quite unven. I took care of the floor in terms of shoring up the joists and such. But I want to level the floor while adding strength to the floor.
My subfloor is 3/4" fir flooring tongue and groove, the joists are supported every 5' by a large beam. The floor is uneven up to an 1" in spots. I want to lay slate down. The use of deck mud sounds interesting.
Does anyone know if using deck mud and slate will be to heavy for my floor. Also do I have to lay the tile down on the mud floor directly. The idea of having to lay my tile out on a decent grid system scares me if I have to do the whole bathroom and if it has to be done quickly.
Any feedback on thickset beds would be great.
Cheers
Toubob
toubob is offline   Reply With Quote
Old 02-15-2007, 12:29 PM   #2
Originally Posted by toubob View Post
Hello all
Cheers
Toubob
If the joists were corrected then why is there still a 1" drop?
redline is offline   Reply With Quote
Old 02-15-2007, 03:04 PM   #3
Hello
I looked at the joists and jacked up the support beams so the joist were level to each other, but it didn't correct the level of the floor. I figured that there might be a bow in a joist or two. The floor is 100 years old so who knows. The floor has a central depression almost like a trough where a wall used to be that I took out. I do know that there is nothing level or straight in the house.
Toubob
Old 02-15-2007, 03:18 PM   #4
Is this on the first floor or second floor?
Old 02-15-2007, 03:39 PM   #5
You can lay a straight piece of lumber across the floor to see exactly where the slope starts and ends. Then when adding tile you could add more thinset to this area, or what I would do is to get some leveling compound....its a concrete mix that self levels. This would fill in any low areas. If you choose this route you'll need to buy a primer that you put on the subfloor so that the leveling concrete will adhere to it.
cibula11 is offline   Reply With Quote
More On This Topic
We've mixed up some more concrete and we're just in the process of finishing off this job here. Put some back in the bucket, here. Once this dries, in a day or so, we can come in and lay our tile and that will finish up our floor. The reason that I'm... Read More »
If you're looking for carpeting you can install yourself consider carpet made in tiles of varying sizes. The major benefit of carpet tiles is the ability to replace only 1 or 2 tiles if staining occurs, while leaving the rest of the carpet intact. Follow... Read More »
We finished our drywall. We put our first coat on yesterday, of drywall mud to seal up all the joints and the nail holes. This morning I came in and finished the top layer of the drywall. I used a twelve in knife which makes a nice wide band here, makes... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com. Now in this segment, I am going to be showing you how to set your tile and applying the mud to the floor. We would let our mud slack off after mixing it for 10 minutes. I have a... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com and in this segment I am going to show you how to mix your mud and get the floor ready for your tile setting. The first thing I want to do is I want to take some of my flexible... Read More »
Leaking bathroom floor patatura Flooring 6 12-06-2008 08:30 PM
Installing Laminate over uneven pine plank floor? tomzpc Flooring 6 04-16-2008 10:07 AM
bathroom floor looks bad!! drb Flooring 13 03-10-2007 10:19 PM
bathroom floor tile job advice needed dbrew Flooring 14 01-23-2007 09:03 PM
Exploring bathroom addition on second floor wease Plumbing 12 12-10-2006 12:20 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
