-   -   old uneven bathroom floor (http://www.diychatroom.com/f5/old-uneven-bathroom-floor-6508/)
toubob 02-15-2007 03:29 AM
Hello all
I am in the process of redoing my very old house. I am ready to finish up a bathroom I recently gutted. The floor is quite unven. I took care of the floor in terms of shoring up the joists and such. But I want to level the floor while adding strength to the floor.
My subfloor is 3/4" fir flooring tongue and groove, the joists are supported every 5' by a large beam. The floor is uneven up to an 1" in spots. I want to lay slate down. The use of deck mud sounds interesting.
Does anyone know if using deck mud and slate will be to heavy for my floor. Also do I have to lay the tile down on the mud floor directly. The idea of having to lay my tile out on a decent grid system scares me if I have to do the whole bathroom and if it has to be done quickly.
Any feedback on thickset beds would be great.
Cheers
Toubob
redline 02-15-2007 11:29 AM
Originally Posted by toubob (Post 33512)
Hello all
Cheers
Toubob
If the joists were corrected then why is there still a 1" drop?
toubob 02-15-2007 02:04 PM
Hello
I looked at the joists and jacked up the support beams so the joist were level to each other, but it didn't correct the level of the floor. I figured that there might be a bow in a joist or two. The floor is 100 years old so who knows. The floor has a central depression almost like a trough where a wall used to be that I took out. I do know that there is nothing level or straight in the house.
Toubob
redline 02-15-2007 02:18 PM
Is this on the first floor or second floor?
cibula11 02-15-2007 02:39 PM
You can lay a straight piece of lumber across the floor to see exactly where the slope starts and ends. Then when adding tile you could add more thinset to this area, or what I would do is to get some leveling compound....its a concrete mix that self levels. This would fill in any low areas. If you choose this route you'll need to buy a primer that you put on the subfloor so that the leveling concrete will adhere to it.
